Sometimes Problem Starting A 1.5 12v
1.5K views 3 replies 3 participants last post by  edyrli
The car is a 1995, 1.5 12v GLS AUtomatic.
Sometimes it starts without a hitch. It is always starting imediatly when warm.
Is is usually worst when it has been sitting for a couple of days.
But if i use starting gas it starts up right away.
I have changes spark plugs, spark plug wires, coils, fuel filer, oil, oil filter.
None of this had any effect.
After reading this forum i am thinking maybe it can be the Fuelpump or fuelpump relay?
Any suggestions?
#2 ·
It could always be a leaky fuel injcetor/s when the car is let sit for some time they leak and leave the system with no back pressure. If it were the fuel pump then it would do it even more when it's hot not less. As for using starting fluid I would not recomend the continued use of it on a V8 let alone a 4cyl, it should only be used on diesel engines and even then only as a last resort as it's very easy to cause very bad internal engine damage. :thumbsup:
#3 ·
QUOTE (accent sport @ Jul 21 2009, 07:49 AM) index.php?act=findpost&pid=250381
+1
