Replacing Driver's side interior door handle - 2004 Hyundai Accent
2.9K views 4 replies 4 participants last post by  2003hyundaiaccentgt
The interior door handle just broke on the driver's side of my 2004 Hyundai Accent. It's a base 2 door model. I can open the door fine with the exterior door handle. It basically sounded like something snapped inside.
I ordered a replacement part already, but not quite sure how to replace it. I've looked online, but seems to be very little about replacing the interior handle of this particular year/make/model.
I'd normally have my mechanic do it, but things are a bit tight financially right now so I'd rather save the money and do it myself.
Any guidance is appreciated.
#2 ·
How do you know the part to buy when you haven't looked at it?
Operation CHARM: Car repair manuals for everyone.
Home >> Hyundai >> 2004 >> Accent L4-1.6L >> Repair and Diagnosis >> Body and Frame >> Doors, Hood and Trunk >> Doors >> Front Door >> Front Door Panel >> Service and Repair
Front Door Panel: Service and Repair
Front Door:
REMOVAL AND INSTALLATION
1. Remove the in side handle mounting screw.
2. Loosen the door trim mounting screws(7EA), remove the trim using a trim remover, and then disconnect the power window switch connector.
NOTE: When using a trim remover, wrap it with a piece of cloth so it will not damage the painted surface.
3. Remove the door trim seal, speaker, and connector.
4. Installation is the reverse of removal.
pro multis · About Operation CHARM
