Update to this thread as I did a front Hub last night. Steps are basically the same as the rear that I posted earlier but no backing plate/emergency brakes to worry about. Like everything in life lots of lube helped.
-Remove tire
-Remove Caliper
-Remove Rotor
-Remove speed sensor
-Remove axle nut
-Remove the bolt holding the lower balljoint into the spindle assemble (Do not have to separate the spindle/lower balljoint/control arm at all) This allows clearance to get a wrench on the two lower hub bolts.
-My dust shield was rusted to nothing so I removed and discarded (Ontario salt belt!)
-Used the same trick as posted earlier with the gear puller to hold the axle back for clearance
-Top two bolts are easily removed used the ground down socket and ratchet as mentioned previously (a pipe for leverage on the ratchet helps break these bolts free)
-Bottom two bolts required a good box end wrench with some hammer persuasion due to clearance issues (socket wasn't going to fit)
-After bolts removed the hub was good and seized into the spindle but a cold chisel and plenty of hammering worked it loose in short order.
-Cleaned up corrosion and bolted up the new hub in reverse order. Applied anti-seize to the axle shaft.
Overall ~2.5 hrs start to finish. Floor jacket, below zero temps and some supervision by my 3yr old apprentice may have added some time to the repair
