Rear Sway Bar by Whiteline
how it sits (better shots later)
the packaged parts
sitting next to the KYBs
Sway Bar Installation Instructions
Tools needed:
Wheel Chocks (4)
Scissors Jack
Jack Stands (2)
Metric Socket Set (Deep and Shallow), to include 19mm Deep Socket
Rachets (Long and Medium Handles)
Breaker Bar (helpful but not necessary)
Torque Wrench
Steps:
> Apply Wheel Chocks to block the front tires.
> Using the Scissors Jack, approximately 8" forward of the jack point, raise until the rear tire is at least 1.5" off the ground. (I did jack the car at this point before with no issues).
> Support at the jack point with the Jack Stands.
> Repeat procedure to the other side.
> Starting on the driver's side, use the 19mm socket & remove the shock's lower nut. To ease sliding the bolt through the shock, use the scissors jack at the shock's mounting bracket. The brake cable might prevent the bolt from sliding through, push cable to clear the bolt. The shock should now be loose & hanging.
> Lower and remove the jack. The suspension will sag so pay attention to the brake line.
> Copy this procedure to the passenger side. For this side carefully lower the jack watching the brake line. Lowering it all the way could damage the brake line (passenger side noted).
> Remove the springs and seats.
> Install sway bar and necessary hardware using ratchets & sockets.
> Reinstall both springs.
> Reverse installation of shocks using the jack for assistance. Retorque nut.
> Everything else in reverse.
Remember to remove wheel chocks and Drive!
Even with a garage full of tools & equipment, this is the procedure I used. I found it just as easy to do it this way. Pretty quick and simple.
forgive me if I missed something
the packaged parts
Tools needed:
Wheel Chocks (4)
Scissors Jack
Jack Stands (2)
Torque Wrench
Steps:
