Hi all,
I’ve got a Tucson 2007 2.0L with 286000kms on it. It is throwing a P0302 code and idles a bit rough. At the same time when you steer while idling the belt screeches (not sure if these two issues are related).
I have installed new plugs, leads and coil packs and the DTC keeps appearing after a while and the car is having the same stutter.
I have also moved the injector that was in cylinder 2 to cylinder 1 but the car keeps throwing P0302. So I’m assuming that means it’s not an injector problem.
Any help would be greatly appreciated!
