Do them quite a few times.. piece of cake.. drain oil ,,, OOOOOPs, you already did that..
(2) lower bolt for A/C,, leave A/C belt on..
(4) hex head bolt for bracket to oil pan,, tap with hammer and it fall out
(2) 12mm 12 point bolt there where bracket was residing
(x) oil pan bolts via 10mm socket
This is where it get fun.. I use a putty knife with flat bottom and taper on other side to make sharp single edge knife for lack of better description.. use that with hammer to tap between oil pan rail and aluminum flange very carefully to cut the RTV grip.. get it enough and you can use screwdriver in gap to make slight load to pull pan remaining grip.. DO NOT DAMAGE the aluminum surface..
I use wire wheel cup and carefully remove remnant goo from engine side, and finish off with red scotch brite pad (I get old ones from our body shop) and finish wipe rail.. apply bead of RTV to pan (wipe pan rail with non-residue solvent).. and wipe engine side of oil, then get pan stuck to engine before oil run out and bite your rail..
Install all the small 6mm bolts and the (4) 8mm bolt for the bracket (leave bracket off, we just starting bolts in holes for align), and the (2) long 8mm 12pt bolts.... tighten the 6mm bolts to 54 in-lb... torque the (2) 12pt bolt to 23 lb-ft,, remove the (4) 8mm braket bolt, and re-install bracket to 20 lb-ft... install the compressor bolt to 20 lb-ft..
Leave RTV sit for as long as possible before add oil and engine running pressure..
Start Fri after work,, have pan off in maybe 35 minute,, have pan back on,, leave sit all weekend, add oil Sunday afternoon late, carry on..
Warranty time is 1hr off & on.. customer sitting in lounge waiting, so it has no time to get a good cure on, and wonder why it leaks again
