i have a 2008 santa fe se i wanted to upgrade my headlight and fog light bulbs but i dont want to go the expensive route with the h.i.d upgrade anyone recommend a xenon type for both headlight and fog light?
Shoot, decent H11b bulbs of any kind were hard to find until recently. I have found no LED plug & play replacement bulbs. The best I can do is the GP-Thunder 7000K lamps, and as you noted, they're blueish (they are standard bulbs, not HID).Are there any LEDs available for the H11B halogens? The side mounted connections are peculiar to the H11B and I don't want to make changes to my car's wiring to accomodate another connection arrangement. There are used car warranty issues.
Are all the LEDs available in only 6000K color temperature? I don't want a bluish light so I'd like to find something like 5000K LEDs..
They both look great, but you are paying a premium for the compact size and the more expensive bulbs are not CREE based LEDs, or at least the other model says it is and not this one. Canada has more variety of LED lamps available likely due to our weird restrictions here, and I was wondering why I didn't know what T1 vice K7 was, but it's the model numbers.
H11b bulb bases are hard to find any aftermarket parts for, and you are almost guaranteed to be taking a dremel to the base or replacing the incoming side of the wiring, so it really makes no difference. The H11 is the same as H11b electrical specs, the B part is just a twist and snap as opposed to standard clip based retention into the socket.
