OEM Spoiler Install w/pics
18K views 31 replies 20 participants last post by  mickeyreategui
#1 · (Edited)
Well here’s a fun Saturday project. If you’re thinking of doing the Hyundai OEM spoiler install, here’s how it’s done. It’s pretty easy if you have the right tools & materials. It took me about 2 hours, not including an hour of dry time. Aside from the obvious stuff, some things you'll need include: primer, sealant, an awl or punch, deburring drill bit, swivel socket adapter, and patience.
I ordered the spoiler from Lakeland Automall (eBay “lakelandautomall”) in Florida. It cost me $175 shipped, including having it painted to my factory color, sparkling ruby. It took a little over a week from order to delivery. I unpacked the spoiler and was very happy with the paint job, it looks beautiful.
The included template is a bit tricky to work with. You line it up on the left edge of the trunk, press to tape it down, and punch the holes. Then you undo all the tape except the two pieces at center, which serve as a hing, and you flip it to the right side of the trunk. If you don’t have it positioned properly on the left side, it will be crooked when you flip it. I had to keep doing & redoing this step, partly because my template had a lot of bends in it from shipping. It helps to pop the trunk and have it open a couple inches while positioning the template.
A test fit before going to the point of no return.
Once the template was in place, it was time to punch the holes, which I did with an ordinary awl and a hammer. One whack of the hammer makes a pretty deep indent!
After all 5 holes are punched, the template is removed and the real fun begins. First you drill each hole with a 1/8” bit.
Then you drill again with a 3/8” bit. This bit is much larger than the bolts on the spoiler, but that will allow some leeway to move the spoiler around for perfect positioning.
After the holes are drilled, they need to be deburred. I didn’t have a tool for this, so I used a round file. Not as good as a deburr tool. Once that was done, all the metal chips were vacuumed up, and the metal around the holes was painted with primer. I used a Rustoleum printer, not a specific automotive primer.
The directions say to wait until the primer is dry. That would be 24 hrs, which wasn’t gonna happen. I used a hair dryer and let it sit for a half hour, until it was tacky to the touch. (I doubt most lot installers even wait that long). Next the directions recommend a coat of paint. I didn’t have any on hand, so I skipped it and went right to the sealant. I applied clear silicone sealant, and let that sit for about a half hour.
Now it's time to install the spoiler. Wipe the surface of the trunk where the spoiler will sit with a 50/50 water/isopropyl alcohol mixture and dry it off. The back of the spoiler has doubled sided tape, which needs to be peeled back and exposed. Seat it through the holes.
As mentioned, there’s some play. Carefully position it so it’s properly aligned right to left, and isn’t crooked. It's not easy to reposition once the tape contacts the trunk, so try and set in as close to perfect as you can.
Attach the five nuts from inside the trunk, tightening them equally. The two outside edge nuts are almost impossible to reach with your hand. I used masking tape to tape the nut to my socket, so I wouldn't drop it down into the trunk lid. You'll need a swivel adapter to make this easy, and I'd recommend a small 1/4" drive. My torque wrench starts at 45 inch pounds, but the spoiler should only be torqued to 20 inch pounds. I had to wing it. Ahem.
Finish up by reinstalling the interior trunk liner and pull handle, and it’s time to take final pics!
One thing I noticed after the install is the trunk no longer goes all the way up when popped, because of the added weight of the spoiler. This is actually a positive for me, I don't like the trunk opening all the way when it's popped.
All in all, this was a nice upgrade for the car. If you have patience and do it yourself, it's really not that expensive, and it looks so much nicer.
#2 ·
Wow! Good job and nice write-up bro! I don't know that I'd have the courage to do that to my car, but you did a great job!! I love the look of the lip spoiler on the Sonata!
This will be a great resource for the DIYer who is thinking of doing this themselves. Thanks for your contribution to the great resource of information on this forum!! :thumbsup:
#3 ·
i did the same thing but got my spoiler from spoilerwingking...112 bucks shipped and painted to match. paint matched perfectly, spoiler arrived in four days. installation was about the same, quite easy..
#4 ·
I saw your post on another spoiler thread, and I took a look at spoilerwingking. When I did some research outside this forum, I found some complaints about fitment (on other brands of car) and people complaining about poor customer service. I didn't want to take the chance, so I decided to spend a little extra and go OEM.
#6 ·
oh, i ordered it on a monday and recieved on thursday....better service than SR at the moment, but i don't want to get into that right now....
#20 ·
Not true. If installed properly there will be no rust. I have done body work on cars here in Vermont. More road salt and salt brine are spread up here per mile than any state in the USA. The major cause of rust perforation on later model cars is caused by poor body design allowing salt water to stay trapped within body panels for extended periods of time. Not spoilers where the holes have been properly rustproofed and installed.
Good job installing that spoiler guitarfish.
#14 ·
Looks good, paint matches perfectly and useful write-up for future members possibly interested in this :)
Enjoy
#16 ·
Agreed, great write up and pics to boot. How did it feel taking a punch and hammer to you brand new car LOL. Looks sweet!
Sent from my Autoguide iPhone app
#17 ·
To be honest, whether it's bought fro Hyundai and US color matched or not.....it's flat out NOT the best looking spoiler for the Sonata. It looks like an afterthought how it sits on top of the deck lid only.
The one I have has the little feet on each edge that wraps around the corner and simply hugs the trunk better, and looks very much more OEM like it belongs on the car from the Factory. Got it on Ebay, Korean Diamond Black is a spot on match to our US black.
#23 ·
Looks great man, good job. I think I want to do it too.
#27 ·
I have an NF but would like to add to this discussion. If you don't feel like DIY and don't care for a tape install, which I don't recommend, go to a local auto trim place.
<<<I had mine installed for $30.00 screw down. I had an inside deal but I would venture to guess if it doesn't have a 3rd brake light I would say $50.00 install would be a good price. As well as giving you piece of mind.
BTW mine was from Spoiler and Wing King in 06.
#31 ·
the one above isn't oem style...as it would have a 3rd brake light if it were. since the sonata's high mounted stop lamp is in the lower part of the rear windscreen, the spoiler needs to have a high mounted stop lamp integrated as well.
#32 ·
the factory spoiler for the sonata does not have a brake light, it doesnt sit high enough to block the third brake light
