Misfire In Cylinder
4.9K views 22 replies 8 participants last post by  sbr711
Hi,
I got a P0302 code from my car. I've changed the spark plugs and spark wires. I'm waiting for a new ignition coil to come in to change that. The other possible causes that I've found from research is a possible faulty or dirty fuel injector or a sticky/dirty exhaust valve.
My question is how difficult is it to clean the valves? I imagine that I would need to remove the valve cover to get at them, but is there anything in particular that I would need to keep in mind to do this? Should I get a new gasket? Is this too difficult for me to do? Will this screw up the timing at all?
Also, what should I use to clean the injectors? I'm not thinking fuel injector cleaner that you put in the gas tank, but actually physically removing the injectors to clean them.
Any and all insights would be tremendously helpful!
Thanks!
Alex
#4 ·
well, the code means that it's cyl. 2.
So I get a new ignition coil and was going to change it out today. Which I did. But on my way back from work yesterday, I'm driving down the highway and it throws me another code. And as it does, when I slow down, I notice the rpms are staying high. Get home and it's a P0121 code. Something wrong with the Throttle Position Sensor. Crap. Now, the car idles at 3400 rpm, doesn't want to shift until it hits 5000 rpm and sits just under 2000 rpm when stopped. I have to jam the brakes and even use parking brakes to keep it from taking off at a red light.
I ordered a new TPS and it'll be in early next week. Until then, I have no idea if the original misfire is fixed and my car acts like an over-excited german shepherd. When it rains, it pours.
#7 ·
I changed the plugs, wires and coil. No help. I now have that TPS problem. Changed that, and no difference.
I'm at the end of my rope, so it's going to the dealer on Thursday. I just hope I don't obliterate my brakes before then.
Now I'm thinking that my original coil and my original TPS are fine. It's probably the harness or the ECU itself. I hope not cuz that means we'll be having a lean Christmas this year...
Anyone interested in a used ignition coil or TPS?
#8 ·
Ok, so my situation is a prime example of why we have trained professionals.
I took the car in to the dealer this morning at 7.30 am, expecting to be without it for approx. two days. Less than an hour later, I get a call from Hyundai saying I had blown the intake manifold gasket. That's it. They charge me $250 parts and labour and I get my car back good as new 3 hours after I take it in.
Goes to show that sometimes DIY isn't the way to go.
Hats off to Hyundai Brossard for being so courteous and professional.
Now I can have a beer and relax.
#9 ·
Nacho, I'm sooo happy for you! I saw that u were in a lot of pain lately. U really deserve that beer, or better - take whole box of them! Just curious: did u notice an erratic sound at the tail pipe when idling? Did u feel the engine shaking when idling? I'm just asking because I know s/b with Lantra that has these two symptoms.
cheers!
mark
#11 ·
Thanks for the update.
Could you add for the record
Could you add how many miles/kmeter are on this car?
What year?
Have you ever had any overheating problems or had to change the thermostat?
From what I have read and seen the intake gasket does not go to often.
Hope you get many more miles out of it.
#15 ·
Nacho, I've reproduced your problem! I was just doin regular checkin'n'stuff when I saw a rubber cap on the back of intake manifold. I think an intake for evaporated gases from gas tank. So, what I did was that I removed the thing while idling and the engine revved up like crazy! I've quickly put the cap back on. Just wanted you to know.
cheers!
#23 ·
QUOTE (ken2400 @ Nov 15 2008, 11:18 AM) index.php?act=findpost&pid=201807
Quite a common occurance... Get an Elantra with mis-fire at 2 or 3............ break out the can of CARB and spritz the intake along the manifold to cylinder head seam...
Of course there is common occurance of fried plugs, and wire ends that are arcing out to ground..
