ok, after a few hours reading, this is the codes i came up with. (still missing some i think)
P1529 - Transmission control unit request to the engine control unit to illuminate the MIL
P0703 Stop Lamp Switch(Brake SW) - Short(B+)
P0707 Transaxle Range Switch Circuit Low Input
P0708 Transaxle Range Switch Circuit High Input
P0712 Transaxle Fluid Temperature Sensor Circuit Low Input
P0713 Transaxle Fluid Temperature Sensor Circuit High Input
P0715 A/T Input Speed Sensor Circuit - Open or Short(GND)
P0720 A/T Output Speed Sensor Circuit - Open or Short(GND)
P0731 Gear 1 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
P0736 Reverse Incorrect Ratio
P0741 Torque Converter Clutch Stuck Off
P0742 Torque Converter Clutch Stuck On
P0743 Torque Converter Clutch Control Solenoid Valve - Open or Short(GND)
P0750 Low and Reverse Solenoid Valve Circuit - Open or Short(GND)
P0755 Underdrive Solenoid Valve Circuit - Open or Short(GND)
P0760 Second Solenoid Valve Circuit - Open or Short(GND)
P0765 Overdrive Solenoid Valve Circuit - Open or Short(GND)
P1603 Can Communication Bus Off
P1604 NO ID from ECU
P1723 A/T Control Relay - Open or Short(GND)
P0715 = input speed sensor
P0500 = vehicle speed sensor
P0121 = throttle position sensor
