LED Rear Reflector Light Lamp $44 shipped
5.7K views 27 replies 10 participants last post by  afpj
#2 · (Edited)
Are they any good?? EXLED seems to be nicer :S
Also...how would you connect those?? Look like plugs on computer fans hahaha
#4 ·
Yea....rather have brighter leds
#6 ·
Wouldnt think you would need to remove bumper. Probably just pop it out and install these...and somehow wire it???
Just that plug...
#8 · (Edited)
Plug won't be a problem. Cut it off and splice into your choice of rear-lighted wires. 2011-2013, Elantra:
Turn Signal: Light Grey
Tail Lights: White
Brake: Red-Orange
Don't forget to ground the negative lead wire.
VoilĂ !
#24 ·
Ground is blk
Option splice to turn signal but you need change to red bulbs
exLED Custom Rear Bumper Reflector LED Lights Kit - YouTube
ok. i finally had a chance to see the video! haha
too small on my phone even though the screen is 4.5" haha
a few questions good sir!
1) at the beginning of the video you took a screw off from the bottom then pushed something out of the way, you didnt bend it, did you? just rotated it?
2) when the reflectors were off, you used a modified soldering gun tip to cut the backing off??? it looks like you chopped it into two halves?
#12 ·
I think the ones off Amazon for 25$ is just the LEDs.
Where as the ones Lou posted is fully made with the housing.
#19 ·
MikePA do post em once you get them installed :D
I still have the exled ones in my cart (pre-built form EXLED).
