I'm about to hit 100k miles and haven't changed the transmission fluid. I bought the car with exactly 60,000 on it and it had been changed then.
I've never done a transmission fluid change before, but I'm not exactly worried about it - pop the drain bolt, let it drain, fill it back up with the exact amount that comes out.
I have two questions, though, because I'm lazy and this would be way easier:
1) I have a transmission dipstick. Do I still need to do the "fill with exact amount that came out" thing or can I just fill it until it's at the proper level on the dipstick?
2) Do I even need to crack the drain bolt? I have one of those big siphon pumps and it has a tube specifically meant for going deep into dipsticks. If I can put it down there and pump fluid out, is that acceptable? Is there any reason why that wouldn't be a good idea?
I feel like my posts are taking over this forum.
