My power liftgate/tailgate is intermittent. Most of the time it does not fully open, see example in this video. Occasionally, it operates fine, which seems to correlate with colder weather.
The following power liftgate reset procedure did not improve the situation:
1. Put the shift lever in P (Park). 2. Partially open the liftgate. 3. While pressing the liftgate (tailgate) close button, press the liftgate (tailgate) handle switch for more than 3 seconds. (the chime will sound) 4. Close the liftgate (tailgate) manually.
I do not believe it is a faulty thermal protection because I don’t get the 3 chimes for that error.
I do not believe it is a faulty anti-pinch sensor because it does not reverse direction.
A quick look at the attached block diagram indicates two potential candidates:
Anybody know common causes for this, or recommended troubleshooting?
Kind regards,
Craig
- Faulty PTGM
- Faulty drive spindles (lift cylinders)
Kind regards,
Craig
