Front seat covers
Here's the front seat covers installed:
Only two fitment issues stand out to me:
- The headrest cover is a little "poofy."
- Where the seat and back come together, the fabric doesn't pull down the sides. It rides up along the plastic cover (where the seatback release handle is). On the other side it rides up where the seatbelt release is. You can see it a little in this photo.
The seat covers have a pocket in the back. I put one of the headrest covers in the pocket to make the pocket more visible in the photo:
Installing the seat covers was a little more involved than you'd expect because I wanted them to tuck down under the seat's plastic trim.
I'm going to describe how that's done because it's a little perplexing when you first approach it.
Passenger Seat Cover Install
1. Remove the plastic cover.
Release the seat back so it folds forward as far as it will go. When you do this, the internal mechanism will hold the handle 2" higher, giving you access to the push pin:
You need to push something into that hole which will press on a plastic latch, allowing the entire plastic handle to come up and off a metal lever. (Also note the screw. You're going to remove that during this process.).
Be careful pushing into that hole, the latch is soft plastic:
That red arrow points at what you're pressing on. It's difficult to know how hard to push. If you have a small diameter punch, you can angle it downward and then "lever" the tab.
This is the metal handle:
The bottom hole is what you're pushing through. The plastic tab latches onto the rectangular protrusion above that hole.
The next step is to remove the screws. You saw one screw in the prior picture. Remove it now. There's another screw on the back of the seat:
(Note: The strap on the left is from the seat cover. I already pushed it through.). You can't access that screw until you remove a carpet-like cover:
Just reach under the seat, feel for this clip, and push it toward the front of the car to unhook it:
The last step is a little complicated. At the front of the cover, underneath the seat, there is a plastic "channel" which slides onto a metal extension. There is a plastic tab that locks onto the metal extension, preventing the plastic cover from sliding forward:
You need to pry that little tab while pulling the plastic cover toward the front of the car. You need to realize there are a couple of clip connections which will impede your effort to slide the plastic forward. (Following photos show the plastic cover removed, and the seat's metal frame. That will make it clearer what I'm talking about here.).
It doesn't hurt to pull the rear and center of the cover loose. That will make it easier to pull it forward as you work with that plastic tab in the front (gently!).
I didn't do it that way until I did the driver's seat. On the passenger seat I flexed the curved part of the plastic cover enough that the channel slipped off the metal extension:
After I did that, I popped the metal connector in the center of the plastic cover:
After the plastic cover is loose, slide it rearward 6" and then straight up to the top of the backrest.
Here is the inside of the plastic cover:
The above shows the plastic channel (and tab you pried, gently!). And, it shows the metal clip.
The above photo shows the two screw holes and a plastic clip.
The metal and plastic clips can be popped loose before working with the plastic channel in the front. Doing it first may make it easier to slide the plastic channel forward. A few photos down shows the metal seat frame which that plastic cover connects to. I'll point out some things about the connectors there too.
One thing to pay attention to is a metal tab near the top of the spring:
It's
very easy for the plastic cover to slip
under that metal tab. That metal tab is rough, with sharp edges. It will gouge your plastic cover if the cover gets under it.
Pay close attention to where the top-rear of the plastic cover is when you're finessing it loose. And, especially when you reinstall the plastic cover. It's really easy as your working the cover into position for it to go underneath that metal flange.
2. Install seat cover
This is where you should watch the FHgroup video, and/or read the printed instructions.
There's some wiring and structural pieces under the seat. I provide photos showing how I routed my straps:
2a. Straps from the rear
That's the side of the passenger seat closest to the door. You see that I routed the strap
above two wires.
That's the side of the passenger seat closest to the center console. You can see how I ran the strap above a wire.
2b. Straps from the front
That's the front of the passenger seat nearest the door. You can see how I went above a wire, and below a large metal "box" thing. (Keep the metal box in mind. We're going to route the side straps through it.).
That's the front of the passenger seat closest to the center console. Here you see I ran the strap
above the metal box thing.
The red arrow points to where the side straps will pass through the metal box thing.
That photo shows how to connect the rear strap to the front adjuster. (Go up through the center slot, and down through the third, outer slot -- the one with the serrated teeth. If you get this wrong, it won't hold its tension.).
Pull the slack to the rear. Make it firmly snug. But, don't go crazy tight. This isn't strong material.
2c. Connecting the side straps.
There are two elastic loops on each side of the seat. The green arrows show how I routed them:
The red arrows show 1) where the plastic cover's metal connector slips into, and 2) the metal extension where you pried the small plastic tab, to slip the plastic channel off the front of the seat.
A couple things to think about.
1. Don't cover that slot with the seat cover. The plastic cover needs to pop into that slot.
2. Going back to when you
removed the plastic cover, notice how the slot is considerably longer than the metal clip that fits into it. I think that's designed to let the cover slide forward when you pull the front plastic channel off that metal extension. (Since the metal clip is wedged into that slot with spring tension, it won't slide freely. You'll have to bang on the cover to make it move. Or, pop the connector loose to begin with.
Returning to the side straps, you'll need to use one metal clip. There will be a little baggie of clips connected to the inside of one of the seat covers. Look for it. It's easy to miss.
I finessed the straps on the console side down under the seat. I reached under the seat and got both looped onto my finger. Pulled them forward, and connected them to one clip, shown above.
Then I used a coat hanger with a hook bent into the end:
I pushed that through the seat frame where shown above. It goes straight through the metal "box" thing under the seat. Using my right hand, holding the clip, I hooked the clip onto the end of the clothes hanger and pulled it through the metal "box."
Now, with my right hand free, I grabbed the hook on this side of the "box" thing. I disconnected it from the coat hanger. While holding the clip under the seat, just behind the frame shown in the photo above, I'm able to get the other two straps onto the clip.
For example, the straps are stretchy enough that I could pull the clip up near the opening in the seat frame (where I pushed the coat hanger through) and work with the clip through that opening.
3. Install headrest cover
I assume you got the general idea from the install video and/or printed instructions. But, a couple things to keep in mind:
1. There are
four straps. One at each corner of the headrest cover. It's easy to miss because the straps tend to retract up into the cover. You might thing there's only two.
2. The instructions seem to say the straps should be tied together. But, I got a smoother fit by tying each one directly to the headrest post:
After it's tied, I slid it up to the top. Again, there are four of those which I tied on each headrest.
Driver Seat Cover Install
The driver side is much the same. However, the driver side has the handle to raise/lower the seat. It has to be removed first:
There is a small notch in one location of that cap. If you pull the handle up it will give you better access to that notch. Pry the cap off.
It will reveal two screws:
Remove those screws and pull the handle off. There's another screw under the handle which holds the plastic cover to the seat.
After that, it's the same as the passenger side.
