Trying to replace headlight and sidelight bulbs i have removed the two bolts and i cant see anymore bolts Can anyone
help
help
Hi and :00000732: to the forum.Trying to replace headlight and sidelight bulbs i have removed the two bolts and i cant see anymore bolts Can anyone
help
Thanks for the welcome, Mr PHi abm and :00000732: to the forum
The passenger side bulb is easy to replace, without removing the headlight, plenty of space to work in. Driver's side is another matter. With standard size hands its a long job, with plenty of swearing and little cuts. A small handed female would find it easier if she knew what she was doing, otherwise undo the two bolts on top, they are the only bolts holding it in, slide the until forward just enough to change the bulb, then slide it back. If you pull it too far forward it comes out of a locating prong under the unit and its a devil of a job to get the unit back in, with patience it can be done with a lot of wriggling about of the unit. There is probably an easy way to do it but as some have said I cant find it either!
