I know you can't wiring led to DRL is doesn't work because DRL out put only 5.7 volts only halogen bulb can work, if you use LED Day Light fog cover you have to hook up to parking light(running light) that not you want to be
I want share one of my trick
1).First turn mode control switch to off position(fuse box by drive)
2). Wiring positive(led) to cigarette lighter+ same with negative or connector to body but make sure you add fuse on + wire.
Now led will on when engine start and off when engine off, for manual control just add switch:00000732:
