How To: Gls Alarm Horn Replacement
20K views 30 replies 14 participants last post by  Herk
So I finally got tired of the weak "weep" sound of the alarm horn on my 2012 GLS and decided to replace it. I believe that the Limited and maybe the SE use a different horn or tone so this may or may not apply to those vehicles.
To contribute a little something to the forum, I decided to chronicle the process.
I started by listening to various sound clips of horns posted on youtube and amazon. Amazon has clips of the Wolo brand horns and Hellas and the others I considered were on youtube. For me, I preferred the sound of the FIAMM horns as they had more of a big car sound...i.e. lower tone and more authoritative sound. As this is just the alarm horn, I decided to stay with a single horn so I wouldn't have to worry with wiring a relay.
Here is the horn I went with, FIAMM 72112 Freeway Blaster Horn.
[attachment=28464:IMG_3252.JPG]
So I started by getting some sound meter levels for the stock alarm horn. All measurements were with the hood shut, from about 10 feet away from the front of the car. Car was on gravel driveway:
Single beep: 68 db
Setting alarm off: 79 db
Replacement Instructions -
1) Get your necessary tools together. 2 butt/crimp wire connectors, wire cutters, wire strippers/crimpers, electrical tape, short amount of speaker wire (3-6"), 10 mm socket, ratchet, zip tie, new horn. Wire shrink wrap optional but recommended.
[attachment=28466:IMG_3265.JPG]
2) Open the hood and locate the alarm horn. It's located mounted to the passenger side strut tower near the firewall.
[attachment=28465:IMG_3248...hlighted.jpg]
3) Use your ratchet and 10mm socket to dismount the whole factory horn assembly.
[attachment=28467:IMG_3250.JPG]
4) Release wire harness from the horn by pressing the connector on the harness and carefully sliding it off. Press here to release:
[attachment=28468:IMG_3251...hlighted.jpg]
Pictures of factory horn:
[attachment=28469:IMG_3254.JPG] [attachment=28470:IMG_3255.JPG]
5) Remove factory horn from the bracket using your 10mm socket and ratchet...we will reuse the bracket for our new horn.
[attachment=28471:IMG_3255...hlighted.jpg]
6) Unpackage new horn and mount onto the bracket where old horn was. I was able to use the factory nut, otherwise use the nut provided with the new horn. I did a couple of test fits after I mounted the horn to the bracket...do NOT mount the horn yet. I left the nut just a little loose and put the bracket in place. With my horn as it is a snail type, I wanted to make sure the opening was facing downward. This does 2 things...1) keeps water from pooling in the horn and ruining it and 2) helps with sound dispersion. When the horn goes off, sound bounces in all direction when it hits the ground. Once I got the angle right I pulled the bracket back out and tightened the nut holding the horn to the bracket.
7) Use wire cutters and cut the wire harness connector off close to the connector. The wires are quite short so the closer to the connector we cut, the more wire there is to work with. Once the connector is off, use your wire strippers to strip the wire and then install your butt connectors by crimping them onto the bare wire.
[attachment=28472:IMG_3256...hlighted.jpg]
[attachment=28473:IMG_3258.JPG]
8) As I wanted a little more slack in the wire in case of future horn replacement and also because the factory wire was so short, I added another 3-4" of high quality speaker wire. I stripped these on both ends. On one end I crimped the female spade connectors as shown here as a test fit on the horn to ensure they were tight.
[attachment=28474:IMG_3257.JPG]
9) I then took these wires off of the horn and used my crimpers to crimp the stripped end of these wires into the other end of the red butt connectors that were attached to the factory wires. Please note which wire is gray (positive) and which is black (negative). Mark these if you need to, to keep it straight which is positive and negative. Test all your wire connections to make sure they are secured and that the wire doesn't pull easily out of your connectors. Then either use the heat shrink or the electrical tape to wrap your connections to make them more water resistant.
[attachment=28475:IMG_3260.JPG]
10) Refer to the horn manufacturer's instructions to find out which terminal is positive and install install the corresponding female spade connector (this was our gray wire) over the male horn connector. Do the same with the other, ensuring they both fit very snug. If they don't use pliers to smash these down a bit to ensure tight connection. Then remount bracket with the horn attached. The mount has a small piece of metal that is bent over, make sure this fits into the hole below the bracket mounting hole on the strut tower to ensure that the bracket can't twist.
[attachment=28476:IMG_3261...hlighted.jpg]
11) Double check that the horn opening is pointed down again and adjust if necessary. Secure everything back up. I also used a zip tie/tie wrap to secure the excess wire to the existing wire harness.
[attachment=28477:IMG_3262.JPG]
12) Shut the hood and test everything. Put your tools away and go grab a beer...you're done!
Final test results using a Radio Shack Sound Level meter:
Stock horn - one beep 68db, alarm going off 79db
FIAMM replacement horn - one beep 68-69db, alarm going off 90 db.
So it's about the same loudness setting the alarm which is a good thing but 11 db higher when the alarm is actually going off! Win-win. Please note that this was tested over a gravel driveway which could lower the loudness a bit...over concrete should be louder.
Here is my youtube video of the before and after. 1st part is factory horn, followed by the FIAMM. Please note that both before and after were shot from the same exact distance...off of tripod that I never moved. They look like they were shot from different distances...was just camera zoom.
Hyundai Sonata GLS - Alarm Horn - Before and After
I am very pleased and no longer have to be embarrassed when arming the alarm. :) I hope this helps at least a few of you.
#8 ·
why have 2 horns (one for alarm and one for horn) just have 1 horn.
what I did was change the actual horn for the car, then i just ran the power wire for the alarm horn to the regular horn. works like a charm :)
#11 ·
QUOTE (VisualMethod @ Jul 31 2011, 02:36 PM) index.php?act=findpost&pid=483800
You sir are my hero.
Glad to help Visual...you are one reason I wanted to post this. You and I were in the same boat being irritated by the weak sound...
It really is a pretty easy fix, IF you have all the right tools. Probably would only take 15-30 minutes. Took me a bit longer but I was taking pics, shooting vids, and drinking beer :)
#13 ·
QUOTE (dadof2vets @ Jul 31 2011, 04:00 PM) index.php?act=findpost&pid=483834
DManInDFW excellent job, lots of detail! One question, does the manufacturer sell the same horn without the attached toes!? :grin:
Wait, did I have a pic in there of my toes...didn't see it but suppose it's possible. Better be glad that's all that showed up...I was nekkid when I did this...haha
#16 ·
QUOTE (dadof2vets @ Jul 31 2011, 09:39 PM) index.php?act=findpost&pid=483960
That is funny! Take a look at your first picture and scroll to the bottom. Good idea with changing the horn!
It's.....eating.......my..........toessssss.
Good thing I took my toe rings and pink nail polish off right before shooting that picture. Jk...no seriously I'm really joking.
Used to work with a (really cute) girl that had a mushroom on her big toe. We always gave her crap about her foot fungus.
#18 ·
QUOTE (Flotsam @ Aug 3 2011, 11:06 AM) index.php?act=findpost&pid=485078
Stupid question, but i will ask it anyway. How do you know if you have an alarm? I have a 2006 Sonata LX with keyless entry. But is there an alarm there too?
If not how difficult would it be to add an aftermarket one?
Climb in your car with keys in hand...push the lock button twice. Does your Sonata honk? If yes, then manually unlock just your door and open it. Does the horn start going off? Yes? Then you have an alarm.
If all else fails, try the owners manual. I'm guessing that you likely have a factory alarm.
If you want a real good alarm, I would suggest going to a reputable car stereo/alarm place and have it done professionally. I would NOT go to Best Buy though.
#20 ·
QUOTE (VisualMethod @ Sep 5 2011, 01:18 PM) index.php?act=findpost&pid=499754
Need some major help. Tried doing this today. Got all the way to the end eager to be done. And the horn didn't work! SO frustrating. My dad and I spent like an hour trying everything and nothing works! Any tips?
Did you veryify that the new horn works? Take power directly from the battery and see if it works. If it does, perhaps the fuse for the horn is blown. Also, did you try the old horn to see if your new wiring jobs makes it work?
#21 ·
QUOTE (Scott2011 @ Sep 5 2011, 04:33 PM) index.php?act=findpost&pid=499774
Did you verify that the new horn works? Take power directly from the battery and see if it works. If it does, perhaps the fuse for the horn is blown. Also, did you try the old horn to see if your new wiring jobs makes it work?
Neither. The only different thing we did is instead of using the butt end connectors, we used wire nuts. But they pretty much do the same thing so...
#22 ·
QUOTE (VisualMethod @ Sep 5 2011, 07:42 PM) index.php?act=findpost&pid=499844
Not a good idea ... wire nuts are exposed to weather and will corrode over time. If you must use these - pack the nut cavity with silicon glue so the wires are insulated
#24 ·
QUOTE (VisualMethod @ Sep 5 2011, 03:18 PM) index.php?act=findpost&pid=499754
I know this is a stupid question, but when you shut all the doors and hit the lock button twice, you aren't hearing anything? This is JUST the alarm, and the alarm arming horn and doesn't sound when you press the horn button on the steering wheel. Also, it won't do anything unless all the doors are shut.
Sorry, I know those are pretty basic suggestions, but just want to start with the simplest of things before moving on.
Also, as someone else suggested, remove the new horn and touch one wire to the positive battery terminal and the other to the negative terminal to make sure you don't have a bad horn.
#25 ·
Yeah, I know this is the alarm/ lock horn. Its what I was trying to replace. And yes, after I wired the new horn up (the sam fiamm one you have), once i pressed lock twice, no sound was made.
#28 ·
dmanindfw, thanks for the write up. I missed this before but the timing is perfect as I'm doing this mod this weekend. I got the "2011 Sonata Plug and Play Dual Horn Wire Harness" from Shark Racing to avoid cutting the factory harness.
