How many quarts does a 2014 accent take for a drain & fill?
5.8K views 6 replies 4 participants last post by  Johns2.0T
I have a 2014 Hyundai accent with an automatic transmission. I am looking to change the fluid, how many quarts does it take for a drain & fill?
#2 ·
2014 1.6 engine takes 7.71 Quarts total each drane and fill you will only get out 3liters or so.
SpecificationMeasurementNote
Air Cond Compressor Oil
PAG 464.50 oz
Air Cond Refrigerant
R-134a0.95 lb
Automatic Transmission Fluid
MICHANG ATF SP-IV SK ATF SP-IV, NOCA AFT SP-IV, HYUNDAI genuine ATF SP-IV or other brands meeting the specifications approved by Hyundai Motor Co.,7.71 qt
Brake Fluid
FMVSS116 DOT 3 or DOT 4 Brake FluidTop Off As Required
As required.
Engine Coolant
Mixture of antifreeze and water (ethylene glycol base coolant for aluminum radiator)4.70 qt
Engine Oil
API - SM, ILSAC GF-4 or Above SAE 5W-203.38 qt
Drain and Refill,w/Filter
If API service SM engine oil is not available you may use API service SL. For better fuel economy, it is recommended to use the engine oil viscosity grade SAE 5W-20 (API SM/ILSAC GF-4). Hyundai recommends Quaker State.
Fuel Tank
11.40 gal
Manual Transmission Fluid
API - GL-4 Manual Transmission Fluid, SAE 75W-851.90 qt
Windshield Washer Fluid
Top Off As Required
Use a good quality windshield washer fluid, diluted with water as necessary.
#4 ·
PAG 464.50 oz
R-134a0.95 lb
Brake Fluid
As required.
Engine Coolant
Engine Oil
Fuel Tank
11.40 gal
Top Off As Required
Niiiice do I get 8 quarts then?
