I needed to call roadside to get a boost.
Turning the ignition resulted in clicking that seems like the battery.
The boost worked fine.
This happened in Sep 2021 and the boost worked but I got the battery tested after.
The "Check alternator for electrical output" was 14.26V.
The "Check battery voltage" was 12.86V.
Nov 2022 the battery was tested as part of a service #1.
"Cold Cranking Amps" was 313 (factory spec is 410).
My question is about BEFORE the boost.
I noticed my main odometer was fine but the trip a and b odometers were reset.
Is that normal for a dead battery?
