Here's what it says. I wonder if they fix fender rust?
ACCENT UNDERBODY CORROSION
SERVICE CAMPAIGN
Your Vehicle is affected.
Hyundai is conducting a service campaign to apply rust-proofing materials to the front and rear underbody on certain model year 2008 – 2009 Hyundai Accent vehicles. This campaign affects such vehicles registered in and operated in Connecticut, Delaware, Illinois, Indiana, Iowa, Maine, Maryland, Massachusetts, Michigan, Minnesota, Missouri, New Hampshire, New Jersey, New York, Ohio, Pennsylvania, Rhode Island, Vermont, West Virginia, and Wisconsin, and the District of Columbia.
During winter months, large quantities of salt are used to de-ice roads in the Salt Belt states, noted above. Road salt and water can enter portions of the underbody leading to corrosion.
What will Hyundai do?
Your Hyundai dealer will treat the underbody with rust-proofing material to arrest the corrosion process. This will be performed at no cost to you. The actual time required to perform the procedure should be approximately one hour, however, your vehicle may be needed for a longer period of time depending on the dealer’s schedule; therefore, we recommend scheduling a service appointment to minimize inconvenience. To schedule an appointment with your preferred Hyundai Dealer, please enter your zip code below.
