21 - 40 of 91 Posts
Discussion starter · #30 ·
It's a harder rubber than the other kinds and heavy why the screws are needed and it's T shaped 90 degree not a 45 degree angle like EZ-LIP ,Not happy with the stick on material they give you it's the cheap stuff lol (white foam double sided)but i have 3m roll any way so not a big deal ok pics
just stuck it on a little on one side so you can get an idea it'a about little less than 1"3/4
Discussion starter · #32 ·
i take it the visible adhesive goes away when you press harder?
I just stuck that on there real quick, it wasn't sticking to well lol ,that stuff sucks so i won't be using it. Real 3m double sided tape is dark grey and less visible but yes you won't be able to see it once it's on right and the screws are all in.
****,,, Looks good.
even with the crappy camera pics.B) Just messin'.
I really like that look over the EZ lip.
Looks pretty much identical to the EZ-Lip from the pictures..lol
Discussion starter · #40 ·
hmm i thought Ez-lip was a foam material ? Guess not ,yes there similar but very different Ez-lip is almost flat and the aero lip is 90 degree T SHAPED ,I need to re do it i want to take the bumper off to do it over and slide it back a little so it's more down not at a very slight angle ,and i screwed up on the decal lol
example
ez lip pics
aero lip closer pic
21 - 40 of 91 Posts
