Engineering Mode
174K views 135 replies 61 participants last post by  mohamed.helmy.m2015
#1 · (Edited)
There's a "secret" feature that all Hyundais from the past decade seem to share. The Engineering Mode allows service techs to access information about the car that we're not intended to know about.
Access this menu at your own risk as there are several tests and settings you may have access to that may result in unintended vehicle function. There is a factory reset just in case, but if you figure out how to sideload apps, be careful as you could easily brick your system.
The infotainment system runs Android 4.4.2. To access the Engineering Mode, go to Setup / General Settings / SW Info/Update. There is a large Update button in the center section with small blank spaces on either side. Press the left space 5 times and then once on the right side. Engineering Mode should appear.
I've only just started looking into the menu here but hopefully there are some interesting infos or settings that could improve your driving experience.
Feel free to share if you decide to dive into this and find anything interesting.
445281
445282
edit: This doesn't seem to work after the Nov 2020 map/software update. Please post if you figure out the new sequence.
#97 ·
That's it, to enter full engineer mode, volume level 7 and press the right button to confirm, volume level 3 and press the right button to confirm, volume level 1 and press the right button to confirm, wait a moment please and them It will ask for a code, its code is 0652 and I don't know how to activate Wi-Fi.
#125 ·
There's a "secret" feature that all Hyundais from the past decade seem to share. The Engineering Mode allows service techs to access information about the car that we're not intended to know about. Access this menu at your own risk as there are several tests and settings you may have access to that may result in unintended vehicle function. There is a factory reset just in case, but if you figure out how to sideload apps, be careful as you could easily brick your system. The infotainment system runs Android 4.4.2. To access the Engineering Mode, go to Setup / General Settings / SW Info/Update. There is a large Update button in the center section with small blank spaces on either side. Press the left space 5 times and then once on the right side. Engineering Mode should appear. I've only just started looking into the menu here but hopefully there are some interesting infos or settings that could improve your driving experience. Feel free to share if you decide to dive into this and find anything interesting. View attachment 445281 View attachment 445282 edit: This doesn't seem to work after the Nov 2020 map/software update. Please post if you figure out the new sequence.
if i update or go into engineer mode is not the same and will it erase all other features ,functions or apps or anything i had already saved and used in the past ?
#126 ·
Tenho um Kona Eletric 2023/24 no Brasil. Eu posso no modo revendedor com senha 2400, mas no modo de engenharia eu tento a mesma senha e não digito. O anexo multimídia.
Me ajudem, por favor.
*google translate -
I have a Kona Electric 2023/24 in Brazil. I can in reseller mode with password 2400, but in engineering mode I try the same password and don't enter it. The multimedia attachment.
Help me please.
(1) Senha de Engenharia Multimídia Gen5W | Hyundai Fóruns (hyundai-forums.com)
