Engine oil burning
3.6K views 24 replies 12 participants last post by  tireman000
Hi guys,
I have bought a 2017 hyundai sonata (salvage) then fix it and it has been inspected by a Certified mechanic (now on the rode) while I'm driving the vehicle I noticed that the engine is burning oil like a lot of oil (2 L every 1000km)
So my question is, will hyundai give me a new engine?
#2 ·
See what others will say, but salvage may not get new engine. Plus, in Canada you must have all oil change records. Are you using synthetic ? If the engine was running on mineral oil, switching to synth will cause big consumption for the next 2-3 oil changes
#11 ·
wesoo you might have stuck oil control rings on your pistons i would try useing a few ounces of white vinegar down the cylinders for 24 hours waite a few houres turn the engine over by hand & pour down some more waite till 24 hours pass after pour in a few ounces of ATF in all cylinders with the S/plugs out crank it over to blow out any residual put back plugs/coils change oil & filter and drive it. i know what your thinking Vinegar? Vinegar is an excellent metal & disolvent cleaner.
#12 ·
I wouldn't pour ANYTHING down the cylinders. Best fix for your engine is shorter oil changes, synthetic oil, and a thick viscosity.
Change the PCV valve.
Don't forget other forgotten maintenance, like engine air filter, spark plugs, coolant/thermostat/radcap, stick with top tier fuel, a quality higher end PEA/PIB based FI cleaner every 5k km, and consider a intake valve GDI cleaning.
Change your oil/filter every 5000 kms. Use ANY 5w40 available in your local stores. Check oil level before each trip and top off as needed. Keep it to the full point. Keep driving. Quality oil and shorter intervals can clean an engine, including the ring pack area, without destroying it with vinegar foolish shenanigans.
After 3-4 oil change intervals, 15000-20000 km, post an update.
If the vehicle looks clean, and all "salvage" repair completed, I would go to ANY hyundai dealer and check for any/all recalls and have them completed. The worse they can say is that it was a salvage and you go on your way. DON"T TELL THEM THAT IT WAS A SALVAGE. If the vehicle is smashed in all over the place, then good luck since its obvious.
Inspection by certified mechanic doesn't mean anything to anyone anymore. Most don't have a clue. Certified means they passed a multiple choice test.
#14 ·
Running a diesel oil will not clean any engine any better than useing Synthetic Oil like you think it does. the purpose of diesel oil in a diesel engine is to fight the acidity build up & the amount of ash & stuff that gets down in that oil it needs to keep it dispersant so it doesent attach to things the purpose of oil is to keep things lubricated & to dispers to keep thing from going bad for the time its in your engine. esters in oil can do some cleaning but the amount found in most oil's wont do much the only ones with high ester's amount are RedLine or Amsoil Amsoil aint bad either.
#17 ·
Nobody knows what the cause is. Not everybody wants to rebuild the engine. Others can't get help from incompetent dealerships or their clueless techs. The threadstarter also stated that the vehicle is a salvage which opens up another can of worms. And, salvages are there for a reason, and rarely will come with a history of maintenance either.
What choices does the threadstarter have at a salvage car budget IF the issue isn't addressed by the dealer?
PCV---- no brainer. If the old PCV is sludged/crudded whatever, then you need to pull the oil pan and valve cover for inspection and cleaning.
Synthetic oil... no brainer. Problem is that some think that it alone allows longer oil change intervals. It doesn't. Synthetic oil is not a fix-it-all.
Thicker oil. Less will squeeze buy. Again, no brainer and wonder why people resist this one the most. Grade is proven by too many to lower or reduce consumption. Its a 1st step attempt.
Oil level. Must be checked often and kept to the FULL point always. This is beyond too many consumers' abilities and I just don't understand why. Stupidity? incompetence? Blind faith or trust? By far, the biggest engine killer that I regularly see is LOW oil levels, usually combined with skipped or negligent oil change intervals.
5-15 minute cold engine flush. If there is excessive crud/sludge, you might want to avoid this one because too much can be released all at once. So, just wait just after 2-3 oil changes intervals, see what comes out, inspect the engine, inspect the filter pleat contents.... then consider the flush.
Yes, oils do clean. Conventional oils do clean. All have detergents/dispersants which varies among spec and marketing that the oil meets. So, don't rule out HDEO oils, even though many HDEO, like PCMO, are moving toward greenie additive packages that are as good as they claim.
Filter inspection... at every oil change, one needs to inspect the filter contents to see if there is anything going on or not.
Don't run to dealer crying about oil consumption when you have a salvage vehicle, unknown history, unknown recalls still pending, .... You have to move this along slowly. Get 3-4 oil change intervals in. Keep driving and keep that level full. See how the dealer reacts to 'recalls' needed 1st, if any. Do any/all maintenance based on mileage/time on vehicle, and common sense. Create those records. Then in a year or so, when you verifed all sludge clean out, if any, when you several oil changes, when you have all maintenance done, try to see if they ignore the 'salvage' aspect or not.
Like the 5-15minute flush, there are oil additives that can be used for the full interval. Again, once needs to know the buildup level before adding anything. So, don't jump on the oil additives, like BG MOA, Rislone, Marvel, Lubegard, STP.... until you have run thru some inspected oil change intervals. Then you can pick one per interval and see what happens.
Typical, when you have excessive consumptions, you are at the hope and pray. Hope and pray that something works. Or, hope and pray that an automaker ignores the inch of sludge in the engine, or the fact that its a salvage. How many lotteries have you won? Keep hoping and praying all you want. Do something NOW and keep doing something. Most want to start threads, do nothing, and then whine and cry about the cost of their engine replacement on a forum.
