DIY Oil Change Procedure for Azera
38K views 51 replies 17 participants last post by  someguy
I just did my first oil change on my 2014 Azera. I though you might like a step-by-step guide, so I wrote up a detailed one for you:
1. You need: Oil filter, 6 quarts of oil, funnel, oil drain basin, socket wrench, 17mm and 27mm 6-point sockets, 17mm box wrench, mallet, torque wrench, disposable gloves to protect your hands from touching used oil.
2. Put the vehicle on ramps. To use the brake to modulate power when driving up the ramps, press the brake first, then the throttle. Keep the brake pressed the entire time. Pressing the throttle first, then the brake, will activate the brake throttle override and drop the engine to an idle. If you then release the brake, the engine will rev to the current throttle position and you may overshoot the ramps.
3. Remove the engine cover by pulling up and unsnapping it from the four mounting posts.
4. Remove the oil filler cap and lift and unseat the dipstick allow air to come in while the oil is being drained.
5. Loosen the oil filter canister cap with a 6-point 27mm socket. A 6-point socket reduces the chances of rounding off the plastic edges of the hex head on the oil filter canister cap. Tear a hole in the middle of a paper towel and place it down around the bottom oil filter canister to catch oil drips. Then, unscrew the cap and lift it straight up. If the filter doesn't come out with the cap, set the cap aside in a paper towel and remove the filter by wiggling and pulling it straight up from the canister. Do not turn the filter as pull up because there is a protrusion on the bottom that fits into a socket. Have a paper towel handy to put the filter into to catch dripping oil. Throw the old filter away. Wipe any oil from the lip of the filter canister with a paper towel, but be careful to not leave any towel residue behind.
6. While the oil filler cap and the oil filter canister caps are removed, use care make sure nothing falls inside.
7. Position the drain basin under the oil drain plug. Remove the 17mm oil drain plug. It may take tapping on the end of a 17mm box wrench with a mallet to break it free. Once the plug is loose, remove it by hand and be ready to pull it out of the way just as it becomes free so your hand does not get covered by oil. At first, the oil will drain in a stream about 6 inches towards the rear of the vehicle, then, as the stream gets smaller, it will move towards the front, so position the drain basin so it catches both extremes. It is good to periodically check the draining stream to make sure it is not missing the basin. The stream will trickle for a long time.
8. Allow 5 minutes for the oil to drain, particularly so that the filter, the filter canister and internal engine will be drained. While the oil is draining, remove the aluminum washer from the drain plug. If the washer is stuck, be careful to not scratch the sealing surface of the drain plug head in the process of getting it loose. Replace the drain plug washer with the new one from the plastic bag in the new oil filter box.
9. Note the exact groove position of the o-ring on the oil filter canister cap. Being careful to not spill any oil that may still be inside the canister cap, remove and discard the old o-ring and replace it with the new one from the plastic bag in the new oil filter box. Be sure you put the new o-ring in the same groove that the old one was in. To keep from damaging the oil filter canister cap or new o-ring, do not use a sharp tool on the o-ring.
10. Apply oil to the small o-ring on the bottom of the new oil filter element, and the large o-ring you just installed on the oil filter canister cap.
11. Align the oil filter element so that the protrusion at the bottom fits into the corresponding socket at the bottom of the oil filter canister and wiggle and press the element straight down into the canister until it seats. When seated, it extends 1” above the canister. Make sure the hole at the top of the filter is exactly in the center.
12. Align the oil filter canister cap so that its internal filter clip fits into the hole in the top of the oil filter element, then press down until the threads engage properly and tighten the oil filter canister cap with a 27mm socket and a torque wrench to 25 ft. lbs. When properly tightened, the cap should contact the lip around the canister. Do not over-tighten.
13. Once the oil has finished dripping, clean off any oil from around the oil drain plug hole and screw the drain plug and new washer back in place, then tighten it to 29 ft. lbs with a 17mm socket and a torque wrench.
14. Carefully clean up any place oil may have dripped on under-car components while it was draining.
15. Verify that the dipstick is still not seated so air can escape from the crankcase as you put oil in.
16. Slowly put 3 quarts of oil in the oil filler hole, wait a minute for it to settle, then put 2 more quarts in.
17. Fully seat the dipstick back in place and install the oil filler cap. Remove and set the oil drain basin aside.
18. Start the engine, make sure the oil light quickly goes off, then check for leaks around the oil filter canister.
19. Check for underhood tools, then temporarily set the hood down. Remove any items from under the car and slowly back it off the ramps, remove the ramps, and pull the vehicle back in place. Turn off the engine.
20. Wait ten minutes, then check the oil level on the dipstick and add oil a bit at a time to bring it to the full mark.
21. Clean up any oil drips from underhood components, then reinstall the engine cover by aligning the four sockets with the mounting posts and pushing it firmly down until it snaps into place and does not easily lift up.
22. Pour the used oil from the catch basin into the empty oil containers and properly dispose of it.
23. Clean up the oil drain basin and tools. Keep the UPC label from the filter box for warranty documentation.
#4 ·
Thanks, but I hope I didn't mislead you into thinking this was my first DIY oil change. I've done hundreds, for decades. This is just the first one I have done on my new Azera. Actually, I have 50 years of DIY experience in just about every area of automotive repair and maintenance, including drivetrain, suspension, brakes, body, HVAC, cooling, electronics, etc. It would be easier to say what I haven't done. I haven't done a lower block rebuild (piston, rods, crankshaft) or a transmission rebuild. Everything else, I've probably done it... many times.
For my Azera, I have chosen to go with synthetic oil, specifically Mobil 1. I chose synthetic oil in the hopes that if there is any tendency for Hyundai GDI engines to develop intake valve deposits from EGR and PCV oil intake, synthetic oil may be less likely to form those deposits.
#5 ·
For most people, having someone you trust take care of oil changes works best. For me, it takes a lot less time and costs less to just do it myself and I never have to worry if they did it right. I don't have to make an appointment, I just do it when I want it done and move on to my next project.
I changed it at nine months on the factory fill oil. I don't drive much more than 4,000 miles a year now, so I have chosen a 3,000-mile oil change interval. That way, I can just keep an eye on the odometer and when it reaches a multiple of 3K, I know it is time. That will keep me from going more than a year between changes which could be grounds for a denied warranty claim.
#12 ·
Happy New Year to All. A special thanks to Mr V for his insight and the time he takes to share his knowledge and experience. regarding the DYI oil changes, i have two questions. Is there a filter you would recommend to use? Also, in the past, i was told to put some oil in the filter (When it was a complete metal housing). but now the design does not permit that on the Azera. Any thoughts on how important it is.
#13 ·
You are welcome. I try to give back to a community that provides me with so much information in return. As I do other maintenance tasks on my Azera, I plan to post those procedures too. It is too bad that there doesn't seem to be a moderator for the Azera forum. It would be nice to have some DIY "sticky" topics.
I recommend only using a genuine Hyundai oil filter. You can buy them in bulk from dealers that sell online at a discount, typically around 25%. I would use a Hyundai filter even if I could get aftermarket filters for free. There is no benefit from using aftermarket filters and you subject yourself to a warranty issue if the aftermarket filter should fail or be blamed for an engine failure. As long as you use a genuine Hyundai filter, you can be assured that it is the correct specifications for your engine and you will not have any related warranty issues to worry about.
As you mention, on previous cars I used to fill the metal filters with oil to reduce the time before the oil pressure light goes off on the first startup after an oil change. However, filling the Azera filter canister with oil is of little benefit because it quickly drains down. I do notice that the oil pressure light goes off immediately upon the first start, so the time spent without oil pressure is probably not that different from any other time you start up after the car has sit for some time.
#15 ·
I do not use any oil or fuel additives unless specifically approved by Hyundai. The only additive Hyundai recommends is a detergent fuel additive every 7500 miles ONLY if you do not use Top-Tier gas AND you are experiencing engine problems related to it. Hyundai does not recommend any oil additive. Using an additive can lead to warranty issues if Hyundai should determine that the additive caused the damage.
Marvel Mystery Oil is mostly mineral oil with mineral spirits and other chemicals added as a solvent. There are many reasons to avoid oil additives. Those with solvents can strip away the thin lubrication layer provided by the oil, causing metal-to-metal contact. Here is a good article on additives: Snake Oil! - Is That Additive Really A Negative? - Ford Trucks Marvel is mentioned halfway through the article, under Detergents and Solvents.
#16 ·
Great article, thank you for sharing Mr. V. I do not use any additives either.
Do you happen to know what Hyundai recommends as the detergent fuel additive, what is considered "Top-Tier gas" and what is not ?
Have you ever heard of Motorkote? It was not mentioned in the article.
I recommend Mr. V as moderator for the Azera forum.
#18 ·
Hyundai recommends that you buy their Hyundai-branded detergent fuel additive at your dealer, but TSB 10-FL-014 shows that it is a 20-oz bottle of Techron Plus Concentrate which you can buy at a local auto parts store.
For a list of top-tier gas, see this website: Top Tier Gasoline.
Motorkoke is just another oil additive that has its own claims and user advocates. Claims from manufacturers are often false or misleading. Claims from users are not scientific studies that compare the same model engine run under the same conditions, one with and one without the additive. These recommendations, though often passionate, are not enough for me to base my engine's health on. I'd stay with Hyundai's recommendation that oil additives are unnecessary. Think about it. Hyundai has to warranty its engines for 10 years or 100,000 miles. If they had proof that a product would be good for their engines, they would be recommending it and selling it at their dealers as they do with their Techron-based fuel additive.
#21 ·
All I can say is that I admire you for doing this work. I think I will let the dealer do mine and it's only $28.95 plus tax where I live.
The two problems I have with DIY oil changes is the mess and also the disposal of the oil and filter.
In any event, I do admire you and your detailed write-up. Thanks!!
#33 ·
Cannot find oil drain plug on my 2014 Azera LTD. I look under engine and see nothing but a plastic cover. Dealer said that this must be removed to change oil, and has many screws, making it difficult. Is it that difficult? Also, I have yet to find any car ramps that allow car to drive up without bumper hitting ramp first, making it impossible to work.
Why isn't oil plug readily seen, other than to make it hard on DIY people?
#37 · (Edited)
Whsere is the oil filter on the Azera? I accustomed to it being below the engine but your write-up seems to say it is on top?
It is on top...you have to remove that large plastic engine cover (pull it up it's on snaps) It does not use those screw on filters it uses a drop in cartridge
Look at post (video) 31 again the engine is the same as ours
#46 ·
How to keep ramps from being spin beneath the car?
I know this is an old thread, but perhaps someone can help clarify something.
I tried to do an oil change on my wife's 2012 Azera and nearly had a disaster trying to get the car up on the ramp. Just when it started to climb the ramp, it spun the ramp violently under the car, and the car came crashing down, trapping the ramp under the side frame.
I wonder if there is some kind of traction control system that is kicking in.
Any help?
#47 ·
It is important to have both ramps positioned squarely in the center of the front tire treads and they must even with each other and parallel. Then, when climbing up the ramps, you have to go very slowly. It helps to use the brake to modulate power when driving up the ramps. Keep the brake pedal lightly pressed the entire time, just enough to slow down your climb. Note that you MUST press the brake first, then the throttle. Pressing the throttle first, then the brake, will activate the brake throttle override and drop the engine to an idle. If you then release the brake, the engine will rev to the current throttle position and you may overshoot the ramps. That may be what happened to you.
Of course, it is important that your ramps have a traction surface. I use RhinoRamps. Good low profile and traction surface. Never had a problem with the wheels spinning.
Once you get the car on the ramps, be sure to pull the parking brake and/or chock the rear wheels for safety.
#49 ·
I have to confess, this was my first ever DIY oil change but the guide was spot-on, I followed all 23 points and for a first timer this was fun, very useful, and the outcome was as expected.
I used an OEM filter with Mobil1 5w30 Extended Performance.
It took me a bit over one hour and this was because I had to decide how to jack the car. I had to read in the forum about jacking and in the end I decided to return the jacks and use the RhinoGear ramps.
#50 ·
The ramps are always faster if you have the space. I do all of my oil changes myself and if you want a faster oil change next time you should get a fumoto valve. It makes it so much faster easier and cleaner. Total oil change time reduced to about 15~20 minutes.
#51 ·
I also used RhinoGear (12k Lb) ramps and it is easy once you learn to climb them :)
They worked fine with my 2015 Azera, no issues hitting the ramps.
With a manual transmission I should have no issues but with an automatic I followed MrVivona's indications and climbed fine!
Last night I changed oil in my wife's 08 Sonata: got a bit messy when removing the filter and oil dripping over the cover from the plug... still, after 45 minutes and a beer, I ended up with fully synth oil change that would be over 50 at Valvoline oil change and it costed me about 20, including OEM filter! Not saying that twice I had to return to the oil change because oil was dripping all over my garage.
Next time I will install one of this fumoto valves to see what is the fuss about :)
