Compression Test Results
510 views 11 replies 6 participants last post by  charlescrown
2017 Elantra 2.0L Automatic
The car has exhaust blowby coming out of the oil dipstick, cant figure out why. I checked the PCV valve and now a compression test.
Did a cold compression test. (I forgot to warm it up.. WHOOPS.) Took all the plugs out, fuses for spark and gas. Cranked 5 times per cylinder.
From passenger side to drivers side:
Passenger > > > > Driver
195psi / 195psi / 193psi / 190psi
I read somewhere the numbers should be around 150.. but whatever i guess?? They're consistent.
#2 ·
Compression seems okay.
Does the dipstick get pushed out? Is/are the dipstick o-ring(s) in good shape?
Is the hose to the PCV valve clear and getting vacuum?
Is the breather hose from valve cover(?) to intake downstream of air filter also clear?
#4 ·
Compression should be recorded at each tick of the gauge and compare to see how it's building.
You may want to do a running compression test or at least a leak down test.
#7 ·
How many niles
142,000
difficult to do by myself
that Cold Compression reading is too high Almost sounds like either you got a restricted exhaust blowing back into engine giving a false higher than normal reading on the gauge or Piston compression rings are stuck is this engine useing any Oil.?
Google tells me this motor should have 170-200psi healthy compression
There is no spark and no fuel during a compression test.. therefore no exhaust
Not leaking oil and not burning oil
that said.. about 10-25% loss of original compression is normal for 100,000mi on an engine, so these numbers do seem a little high, given it has 142k. It is a brand new compression gauge, 20 bucks off amazon :) The car passed smog 1 month ago.
-Is the hose to the PCV valve clear and getting vacuum?
-Is the breather hose from valve cover(?) to intake downstream of air filter also clear?
^^ I'm going to check these two things and report back here
