Some on here are fine with getting 22-24 mpg (U.S gallon) in the very cold -10 C and lower in the first 30 min of driving. I however was not. What if your drive was just under that? All winter, 90 % of your driving was at that very low MPG.
So, installed a block heater for the ICE. No real change. Next, install heater into secondary cooling system. The somewhat jerky starts were mostly gone but watching what the ICE was doing with the battery got me thinking.
Now we all have tried to shut off the heater even with the ICE fully heated up but still no go. ICE would run for the entire drive even with heater off. Now our battery's are not liquid cooled like most other's are witch in the very cold can help to heat up the battery. The next thing I tried was I took the plastic cover off the battery and place a heater (like you would have at your feet under a desk) with a thermostat and had it about 10-12 inches away at low heat. Our battery's only need a little heat. Our's are more efficient than others so don't generate as much on their own hens the air cooled as to the liquid. This is what the ICE and momentary low power use of the electric motor was trying to do. Bring the battery up to temp.
I have done this for four days to make sure I got consistent results. Now this was done only with the heater in the trunk on. Didn't have the cords to run to trunk and block heater etc. The result is with backing out of the drive way, turn the heat off the ICE shut off right away. Full EV mode was available. When underway with ICE recharging bat turn heat back on. When bat at 3/4 and EV mode would kick in or when coming up to light turn heat off ICE would shut off. In about 5-7 km or 3-4 miles the ICE would be heated up to the point you don't have to shut off the heat and the ICE would shut off itself as normal. (of course you could just wait for the ICE to heat up but was doing this to see if it worked)
Over the past four days, in my 26 min drive, I have seen the car go from 22-24 mpg to 34 mpg. Massive improvement. I'm telling you. Those of you in real cold, not this 23 F stuff. Try it. Just a little heat is all you need. Don't try to cook them.http://www.hyundai-forums.com/images/smilies/smile.gif
