At about 9000 miles and just got a check engine light.
The center dash says “A possible condition with your Engine Control System Ha’s been detected. A full system check is recommended to be done when convenient. Please contact your local dealership to schedule an appointment.”
I eventually got to the dealership and they fixed it with software.
“Scan code and found P144100 EVAPORATE system downstream purge control valve hose (history).
Inspect and found TSB 22-FL-003H for this DTC. TSB states performed ECU update.
Completed ECU update, reset light and road test. No more check engine light on. Verified repair.”
just wanted to share that is just a quick software fix if you see this message.
