FYI - for those who are interested in upgrading their battery (-) grounds...
There is a 6 AWG chassis to transmission (6 M/T) ground under the air filter housing. I added a 4 AWG battery ground cable to the chassis at this location with a 19" pre-made cable from AutoZone, which is the perfect length. You need the kind with bolt holes on each end.
The existing 4 AWG cable that is attached on the strut mount is soldered to the negative battery terminal, so removing the 10mm nut from the top of the terminal does not disconnect the battery. Just saying that so you know you don't have to worry about reprogramming your radio or anything. I also added a 12 AWG jumper (custom) from the M/T ground to the T/B.
Now there are (2) 4 AWG battery grounds, which in my experience, helps the efficiency of the charging system.
Total time to install was about 1 hour, including soldering the eye terminals on the T/B ground jumper. If you skip this step, you could have it done in 15 minutes, tops.
