I changed my Sonata's coolant at 72K last week(I bought the car when it had 71K miles and found out that coolant change, which is recommended at 60K, has never done before). It's much harder than I thought as it took me about 8 hours to flush 99% of the coolant out of the system. It's because every time you drain the radiator, only roughly 50% of the coolant comes out. The rest of them is still stuck in engine block and heater core. So, I flushed the radiator 5 times to have the liquid coming out almost clear. It's a painful process because you every time you have to run the car for 20 mins to bleed the air out. Then, you have to wait for about one hour to let the car to cool down before you can open the pressure cap to drain the system. When draining, I spilled some of coolant on my hands. Now my pinky finger and ring finger on my right hand are so itchy and dry. Initially, there were small bumps. When they break, there was clear fluid coming out. It that resulted from coolant poisoning? Should I go to doctor?
