Battery life on the key fob
14K views 32 replies 19 participants last post by  rubiriac
On average how many years can the battery of the key fob last?
#2 ·
Well, it really depends on some factors.
  1. What was the original life (charge) in the battery that was inserted?
  2. How often do you use the push buttons on the key fob versus the passive NFC (fob in car) to start the car or unlock the door when you are walking up to it?
    1. Pressing a button transmits a RF signal that is hundreds of times more powerful and battery draining than the NFC connection.
  3. How often do you take the fob with you when you park the car in the garage versus just leaving it in the car. Taking the fob out of range will cause the fob to stop communicating constantly with the car. Leaving it in the car keeps the NFC connection open and the car always knows that the fob is there. Albeit a smaller drain than pressing and/or holding down a button, it's still a larger drain than having the fob out of range and going to sleep.
So, how long should it last? Your own personal use will determine that. But I would say that at least a year and a half to up to 3 years is a good target zone.
#3 ·
Generally they should last a few years at least. As @Bookworm has said, there are a number of factors involved. The latest (2021 onwards) keyfob shuts itself down after a few mins of not moving, and if you put it into a faraday bag, it will communicate less.
The car will inform you when you start if the keyfob has low battery, so it's probably useful to use both keyfobs from time to time to check them.
Once you get a low-battery alert you would have a while to change it, so it's not as if you need to have a spare battery around.
Murphy's law though - if you mainly use one keyfob, when it goes flat, you will likely find that the other keyfob has a flat battery too.
Lastly - if it goes completely flat, you can pop the key out the back of the keyfob to unlock the door, and start the car by pressing the silver part (key part) of the keyfob against the start button to start the car.
#5 ·
Use only genuine Duracell or Energizer batteries. 'No brand' alkaline ones will last you only a few months. As other mentioned, the fob may keep 'talking' with the car when it's parked at home - keep the fob as far away from the car location - i.e. not by the door near the driveway, or keep it inside a faraday bag and make a test for the bag, try starting the car with the bag near the start button.
#10 ·
The best batteries for fobs have always been Panasonics, in my experience. And that's what I use. The main reason was the others' surface wasn't liked by fobs, but I'm sure they're better now, so it probably doesn't matter anymore. But just wanted to mention it :). I typically replace the batteries every 2 years, just to be proactive. Still have several that have to use before they expire, hence the practice. But as mentioned earlier, the car actually tells you that the fob's battery is low, so it's not necessary.
#12 ·
I've replaced mine twice in the fob I use the most (the other spare is just sitting in the house and rarely gets used) and replaced that one once. Vehicle is 6 years old (well in a few weeks). In my old 2005 Chevy Equinox POS (which was NOT proximity based), I think the fob battery lasted close to 10 years, but that was not a PTS or proximity fob.
#14 ·
I have an alert on the bluelink app that just says "Smart Key Battery" along with "washer fluid". I'm certain that the washer fluid isn't low.. Not sure about the key battery if its really low or anything, but my key is usually pretty far from parking lot that I tested it cannot communicate with car (lock /unlock).
#19 ·
I don't think it matters; it's close enough that either side should work IMO. By the way, I have a key card hidden that I'd use if something happens to the fob. It was pretty cheap at $30, so I recommend getting one. It's a shame my 2023 G70 2.0T SP doesn't have that feature. The 3.3T SP I returned did, so hopefully in a future software update. We'll see.
#23 ·
Key cards also require a Card reader (mounted on door) as well.
The car either comes with that feature, or it doesn't. My Calligraphy does... but it didn't come with a key card; I had to buy it separately for 30 bucks. But it's easy to program: Just put the key card where you charge the phone wirelessly, put both fobs somewhere in the car, select 'key card' from the vehicle settings menu, then scroll down and hit 'save'. And done. I tried the ignition with fobs away from the SUV, and it worked, but didn't try it to lock the vehicle. I leave it hidden inside the SUV, in case I lose the fob, so no need to open the doors anyway; I'd do that with the phone app. Wish my 2023 top-trim 2.0T G70 came with that feature, but it didn't (only 3.3Ts).
#31 · (Edited)
There will be telltale signs when the key fob battery is weak. For me, it was unable to unlock door on the 1st time, it eventually unlocked after a few more presses on the door handle button. This unlock inconsistency persisted for ~4 days, then decided to change the key fob battery....and problem fixed.
#33 ·
hi here i have a hyundai elantra sport 2018 tech package and my first battery last like 3 years and after that like 1 year and a half but in the last year or so i need to replace battery every 3-4 weeks.. always used good energizer one replace my key fob with the other spair that i have tried faraday bag to keep the key in it nothing seem to solve the problem any idea ?
