I know people get anxious when they see the check engine light.
I got one day. I found out that if you are near empty, leave the engine running while pumping gas...it triggers a check engine code as "small leak". I reset the code and not 1 problem after. You are also supposed to not refuel with engine on anyway!
One other time I got the same check engine light and same code...cause was fuel cap not clicking (sealing properly). I ordered a Hyundai replacement cap which clicks when turned and no more errors. The Azera is one of the most reliable cars of any brand so look for the small stuff first.
