According to Tucson Tl 2017 Manual Page 2-54:
If the passenger’s front air bag ON/OFF switch malfunctions, the following conditions may occur:
The passenger air bag OFF indicator will not illuminate and the ON indicator will come on and go off after approximately 60 seconds
(and one more condition)
We recommend that an authorized HYUNDAI dealer inspect the passenger’s front air bag ON/OFF switch and the SRS air bag system ASAP.”
I read this part of manual and became curious about my car because as I press ignition button , passenger’s airbag ON/OFF switch illuminate with together for a second and then go off together ,after that,ON indicator illuminates for 60 seconds and then goes off and it stays off up to next ignition.
I went to dealer to scan and inspect ,after scanning the Airbag &SRS He said “No trouble found”.Unfortunately dealer is not an authorized inspector (and I could not find an authorized one around), so I am still suspicious of passenger’s airbag .
I need to ask those who own Tucson 2017 Tl if the conditions I described are normal or should I continue to worry?!
Thanks
Thanks
