A/C compressor removal Subframe in way
3.4K views 31 replies 7 participants last post by  Jimjeep
2011 Sonata limited with 2.4. New engine from Hyundai at 250K
Looking to change either A/C valve or compressor itself, will try valve first.
Form everything I can find it looks like a somewhat straightforward job but when i get underneath it looks like there is a subframe in the way that i cant find any mentions of and it looks like its really in the way.
It caused me problems when i did the starter a few years back as well if i remember correctly
Any ideas?
Thanks in advance
#2 ·
I've never removed the compressor, so I can't say if you are referring to the same thing.
when doing the starter, if you are referring to that large metal plate that when removed makes it a whole lot easier to then remove/reinstall the starter, why not just remove it? that is of course if you are talking about what I think you are. wouldn't call it a sub frame though, I think it's called the intake manifold stay.
#3 ·
Im not sure what it is but on the videos if seen and the discussions on this forum no one else mentions dealing with it or shows it. Its not just the skid plate type protection that is easily removable it seems more substantial then that. It looks like it goes form frame rail to frame rail. Ill have to take a closer look when i get the skids off.
thanks for reply
#9 ·
Dont have pic, but will take when i get skid/protection off. Never posted a pic here yet either.
In the video above it sits right below the rubber hose. You cant even see the valve because of it.
I can reach the valve from above but having trouble disconnecting wiring and will then have trouble finding the o-ring holes.
#15 ·
Just found this video on a 2007 and you can see just below the oil filter there is some sort of crossmember.
I'm guessing i have an early 2011 where they used some bits from the previous model. Hopefully when i get the bottom protection off I can get enough room to try just replacing the valve, If that doesn't work looks like I may have to pull radiator and fan and come in from the top. Don't have to worry about evacuating the system as a deer hoof recently did that for me.
#19 ·
Nox32, Check yours first, most others seem not to have this and there is nothing in the way. Without it it seems like a fairly straightforward job. Most only have to take off the "skidplate" protection. Look at the video Turbonut posted, that is what most people seem to have.
Not sure of VIN, will check.
#29 ·
Yes, the first time I changed the control valve the gauges showed 0 charge. As I was removing the cap to replace the desiccant bag first, gas was coming out under pressure when it stopped I replaced the bag then tried to remove the control valve which was a little tough but easy to get to. The second time I changed the control valve I only replaced the valve and again the gauge said 0 but the thing flew out under pressure with no effort. I didn't add r134 but even after pulling a vacuum for a couple of minutes it still had some in the compressor.
#31 ·
Lube the O ring with refrigerant oil and should go in easily, but I had one they sent me that was @ 1/8" too long so check the length to be
certain it's the correct length. The one I received was listed for the correct application. Also, make certain the 2 pins are perpendicular.
Had one that when received one of the pins was bent, didn't see it during installation, pushed the connection on, tried to charge no go,
so pulled the plug and checked the pins, one was bent down but so thin that it broke when trying to straighten it out, but they replaced the
valve, no problem, but caused quite a delay with added work/refrigerant.
#32 ·
I ended up breaking the end off the valve and had nothing to pull on and because i have the subframe in the way no access to get at it, also no access to refrigerant to try to pressurize.
Ended up buying new compressor and swapping the whole compressor. Since my 2011 has a subframe in the way I had to unbolt the compressor and wedge it up in the bay. I then had to remove a molded compressor mounting bracket to make room to drop compressor thru bottom. Without subframe it would have been much easier. Tried taking off oil filter but that didnt leave enough room, also tried pulling out from above but that looked like removing the fan at minimum to make enough room.
Hope this helps someone. Going to get charged at shop tomorrow so my fingers are crossed.
