87, 89, Or 91 Octane?
1 reading
90K views 52 replies 31 participants last post by  Circuitsmith
This is my first hyundai, so I'm just curious what octane gas are people putting into their Elantra. Would 87 gas work or are you guys putting the 91 in?
#2 ·
87 will be fine for our use. Car engines are tuned for certain octanes of fuel. If an engine is designed to use 91 and you put in 87, the knock sensors would step in and adjust the timing so that the "knocks" would not develop. You would not get the same performance out of the car nor would you see similar MPG numbers as well. Now, if you put 91 into a car designed for 87, you would not really gain anything and just be spending more money on fuel than you need to. One of the many great selling points is that the Elantra gets 40 MPG on 87 octane fuel. If you look at other cars such as the MINI, sure it may get 37 MPG but it uses premium fuel. I guess what I'm saying here is that to save your money and spend your money on different mods to your car such as tint, engine pad, chrome pedals, etc. I hoped this helped.
#4 ·
The Elantra was designed to burn 87 and cannot benefit from higher octane fuels. Use 87.
The word "premium" is misleading, because it implies "better" which is not the case. Premium fuel is simply more resistant to detonation, which is not an issue in a moderate-compression engine like the Elantra has. Some companies try to entice you to use premium on the basis that it has more detergents, but it would be far cheaper to simply add a bottle of cleaner every so often. And these extra cleaners are not necessary according to Hyundai.... regular fuel contains enough of them.
#33 ·
+1. And, according to some experts (Pat Goss - Motorweek), you can actually cause problems when using premium in an engine not designed for it. Use what the manufacturers recommend. From my own experimentation with this over the years with many new vehicles, I've never noticed any difference in performance or mileage when playing with using the different ratings. The only difference is cost.
The other thing people refer to a lot is "pinging" (pre-detonation) sounds. If your car is actually "pinging" when you mash the go-pedal, it needs to go to the dealer, 'cause it ain't the gas... it's a mechanical or computer issue. Modern cars make a lot of injector/egr valve/ noises that cars of the past didn't make.
#11 ·
Here ethanol is hard to avoid with exception of a few stations located near the boat docks.
I did use the 87 non ethanol on a past car and found the car to run smoother and with more pep.
#12 ·
#16 ·
QUOTE (northy @ Jun 28 2011, 01:02 PM) index.php?act=findpost&pid=468295
pull up to the pumps and read,,,
or better yet call 1-800-661-1600 and get it from the horses mouth
the long and short to all of this nonsense is that the elantra along with ALL other cars manufactured today are designed to run on 87 octaine fuel which contains Ethanol. the ONLY time you should use otherwise is if the car needs it.
#20 ·
QUOTE (Elan1 @ Jun 28 2011, 04:31 PM) index.php?act=findpost&pid=468483
OK, on pg. 1-3 on the 2012 owner's manual it says "Your new vehicle is designed to use only unleaded fuel having a pump octane number ((R+M)/2) of 87 (Research Octane Number 91) or higher." So, does it mean that when they said 29/40 mpg they are based on 91 octane?!?
It's referring to the two different ways of calculating octane number. Notice how on fuel pumps somewhere, it has the octane rating and then in small writing under that it usually says "(R+M)/2 Method"
Some places use a different calculation that results in a different (higher) number and that is called RON. So if the pump says 87 R+M/2, you're ok. If the pump says RON, 91 is ok.
Disclaimer: I'm no expert, I just saw this post and went to google and got the answer.
Source: http://www.carbibles.com/fuel_engine_bible_pg3.html
#21 ·
QUOTE (silverfoxc @ Jun 28 2011, 04:53 PM) index.php?act=findpost&pid=468489
Cool... thanks
#22 ·
QUOTE (Don67 @ Jun 28 2011, 12:57 PM) index.php?act=findpost&pid=468292
What the heck is "regular unleaded ethanol gasoline"? All I see at the local Shell stations is Bronze, Silver and Gold/V-Power, none of which list ethanol in their MSDS.
That is gas which is regular as opposed to premium (91+) or mid-grade (89) that is unleaded since gas used to be leaded but went out with the advent of catalytic converters AND has up 10 10% Ethanol. Hope that helps.
#23 ·
QUOTE (ranjo @ Jun 29 2011, 08:42 AM) index.php?act=findpost&pid=468699
Thanks ranjo. My question was really Shell-specific, however.
Up here in Canada, Shell pumps display three grades of gasoline: Bronze (87), Silver (89) and Gold/V-Power (91). According to the MSDS sheets, all three grades are ethanol-free. But there's a mysterious fourth MSDS sheet for "regular unleaded ethanol gasoline", which does not appear on any Shell pump I've ever seen. I'm wondering where this fourth grade fits into their product shelf.
#30 ·
Fourth one "regular unleaded ethanol gasoline" refers to E85 blended fuel. (similar to Bio diesel for the diesel guys, B100 = 100% bio diesel, B80 = 80 % bio 20% regular diesel, etc etc.) so E85 = 85% ethenol 15% regular gasoline.
(hope that answers your question). Oh and the pump for E85 is a different color (cant remember what color the pump is but its clearly a different color & listed as e85 fuel)
#24 ·
QUOTE (Don67 @ Jun 29 2011, 08:57 AM) index.php?act=findpost&pid=468707
don67 im not sure what answer you need which alread hasnt been specified???
#25 ·
I actually filled my 2nd tank up in Premium, worse mistake of my life, will never do it again. Aside from wasting $$$, it bottlenecks my engine, giving me only an average of 19mpg combined when I should be getting like 26+.... Ugh first world problems.
(2012 Black Elantra GLS w. Preferred Package)
