Anyone else have a similar issue where on light load,just cruising on highway at around 59-60mph there is a shudder that can be felt in steering wheel and even in gas pedal?
1) Check tire pressure -- should all be similar if not the same. Also, should be above minimum when cold.
2) Could be an alignment issue if otherwise ok.
Thanks!!! I check tire pressure weeklyi if not more and make sure its pefect.
Alignment seems fine
It is a EL Convenience
Seems like possible transmisstion issuse if you ask me. Hyundai said they cant replicate it even though you can faintly feel it in the passenger area as well
Hopefully not a lane assist or other similar issue.
You don't mention which model you have, btw. It's possible to add that information into your profile, if you wish, so that it's always visible to others to help in answers.
100% no. Took 6,000 mile trip this summer across the country FL to CT then to Arizona. Smooth pretty quiet.Anyone else have a similar issue where on light load just crusing on highway at around 59-60mph there is a shaking that can be felt in steering wheel and even in gas pedal?
If none of that works and u live in a state with a lemon law see about exercising your rights under such! Or at least threaten to do so!!Write to the CEO. Certified letter. Tell him its a new purchase, get the dealership response and the diagnostic fee. Hopefully, you'll get a favorable reply.
We have done that on other purchases with great results.
I'm also surprised that the 100,00 warranty didn't cover the issue. Plan B would be to take it to another dealer and see if they can fix the problem.
Good luck and keep us updated.
