Is there any difference in the 2 that might hurt my car?
Correct :thumbsup: I use 5/20 in the winter (cold here) & 5/30 in the summer (hot here) :grin:5w 20 is a thinner oil than 5w 30. These two aren't very different from one another, but it's still good to go with the recommended oil that is in your manual. The type of oil to use also depends on where you live, whether you live some place with extreme hot weather all the time, or extreme cold, or in the middle.
Mine calls for 5w20 year round. Could probably run 10w40 during the summer but they are recommending 5w20 forRead the manual people, 10w30 is the standard oil (very common), even the 5w30 is considered a "thin" oil only to be used when ambient is below 50F down to -13F or so on a regular basis for these cars. 5w20 is rated for 14F- -13F.
So there's no point in even considering 5w20, the oil is too thin and the potential for oil starvation (thin oil = low oil pressure = low circulation of oil through passages) is there once the engine has reached operating temperatures.
The only time I have ever used 5w20 is when the manual says so; this grade of thin oil is mainly used to satisfy fuel economy regs (thinner oil = less drag but again at the expense of lubrication), and unless the engine is designed to run on this oil I would be highly reluctant to run it, especially during the summertime.
You have an 09, the engine is most likely different. Also who is doing the recommending? Just look in the owners manual, the temp ranges and oil weights are listed pretty clearly.Mine calls for 5w20 year round. Could probably run 10w40 during the summer but they are recommending 5w20 for
a reason :whistling:
Where did you get this info?I forgot to directly answer your question. The difference between say a 5w-20 and a 10w-20 is that the 5w-20 thickens less after you turn your engine off. Remember all oil is too thick at cold start-up. But a 5w-20 is still not at thick as a 10w-20. These have the same viscosity. Thinner oil also runs cooler due to increased flow.
The difference between a 5w-20 (20 grade) and say a 5w-40 (40 grade) is not that much at operating temperatures. But during startup it's significant due to pressure and flow dynamics. These have different viscosity. Which is important during cold start-up.
Oh, also, generally speaking a fully synthetic oil is better than a conventional mineral based oil in cold climate applications. The start-up viscosity of the same grade oil is different. The synthetic uses less energy to crank the engine. At normal temperatures a conventional mineral based oil provides the same amount of protection a fully synthetic does. Fully synthetics typically lasts longer due to their additive package.
Whatever you choose, use a only an SL - SM, or soon to be widely available SN rated oil. And Never race your engine until the oil is warmed up!
