2022 Limited Transmission
1.5K views 10 replies 5 participants last post by  Rawrdawg
Simple question...Is the DCT transmission serviceable or not beyond filter,etc?
Reason for question is we had the recall performed last year...just software update as there was no code and it worked just fine. Last week the transmission started slipping, not shifting, and hang-shifting. The DTC didn't appear until I shut off and re-started the engine.
So we brought it into the dealer and they confirmed the failure was the high pressure electronic oil pump...aka, the recall issue.
Dealer said they ordered a new HPEOP. That's when my BS detector went off, but I didn't reply with skepticism. I just said OK, let me know when the car is repaired. I figured Hyundai got sick of buying new transmissions and figured out a repair procedure for the pump.
Fast forward to just over a week later and the service advisor calls to say the tech. tried to repair the HPEOP, but it still doesn't work so now the car needs a new transmission.
And that's when I dropped all pretenses that the dealer wasn't giving me a line of BS from day one. The BS is that the transmission is serviceable and they knew exactly what needed to be done, but are behind in service jobs so they created a plausible story for the delays.
I talked to the advisor until he basically blamed me for being pissed off. The service manager wouldn't answer if the transmission is now serviceable nor why their techs. order expensive parts only to realize they should have contacted Hyundai service first in order to just get authorization for a new transmission.
This last part was brought up because the advisor told me they ordered the part because the tech. believed a new HPEOP would fix the problem.
#4 ·
52,000 almost on the nutz. Of course it occurred out of nowhere and hour away from home. But after kid's LaCrosse game it ran fine. But reoccured many more times.
At 20k miles the electronic coolant manifold failed which would cause the engine temp. to swing violently into overheat warning.
After the car sat at dealer for over a week, they called and said no codes, can't duplicate and good to go. I took the tech. for a ride and drove the tires off of it to get the engine went into overheat. They didn't believe me until I showed them. I wasn't mad with them at that time because when the error occurred first, the air temp. was a freak hot week during the Fall, but when I dropped of the car, it was in the low 50s. Still, engine needed to be in heavy/sustained boost to show the failure.
My point is dealer us causing issues for Huundai and Hyundai isn't the best quality car maker nor trainer for their dealer techs.
Just too much bs answers that cause me to scratch my head and this transmission deal really pissed me off.
#7 ·
The failure (if it's the high pressure oil pump) is a soldered connection on the pump circuit board, so there are a number of things that could factor in. Some just aren't going to break as soon, some may not be exposed to as extreme hot and cold cycles as other, types of roads driven on could be a factor (vibration), etc. It does seem as though most have failed really early, though. There have also been some other types of failures of the DCT. Mine went right around 9,000 miles, FWIW. The replacement now has 7,000 miles and has exhibited some concerning behaviors off and on, so just waiting...
#9 ·
If you're asking me, mine is AWD. The Sonata N-Line and Elantra N use the FWD version, But I have not researched to see if they have also had pump failures. The percentage of Santa Fes that are FWD is probably pretty low, so I think those other models may be a better place to look, but maybe I underestimate the number of FWD SFs sold.
