2008 Elantra, US, 2.0 Auto. Weird clacking sound from ?engine? ? Details in post.
1.3K views 1 reply 2 participants last post by  OTR22
I've got an 08 Elantra with ~127k miles on it, 4 speed auto. USA so it's the 2.0 I4.
I haven't driven on the highway much since COVID, but recently took a 700 mile round-trip and noticed what I would describe as a clacking sound. It's at around 70-75mph and around 2500-2750rpm. I can't really hear the sound with the window down at that speed.
I had a stretch of ~15 miles at 65mph (~2200rpm) where I could hear the sound, but a stretch of ~15 miles at 80mph (~3,000rpm) where I heard nothing. Up/down hills through Upstate NY with it coming and going between 70-75mph.
The sound was a bit more pronounced accelerating uphill, and when letting off the throttle the sound would increase just a tad, before becoming significantly less pronounced. (Think just as you're cresting the hill and start coming down, you ease off the gas. Easing off the gas the sound drops significantly, but letting off the gas the sound is a tad louder for ~0.2 seconds before becoming significantly quieter.
I did recently have my oil changed at a Pep-boys when getting new tires put on, so they probably used a non-OEM oil filter. (first time a non-OEM filter has been used). I've read on the forums that this could be an issue due to pressure in the oil system.
I need to double-check tomorrow, but it seems like it's an RPM based issue at around 2500-2700rpm and not a speed based issue. I did drop the car from 4th to 3rd on the highway (forget what the RPMs jumped to, maybe ~3500), and it sounds like the sound is still there a bit. I also drove in a parking lot in 2nd gear to bring it to 2500-2700rpm and that clacking/chatter comes and goes.
I also drove it at around 70-75mph in 3rd gear for about 10 minutes on the highway, since "if this ****er is going, it's going close to home".
At the first rest-stop, I pulled over and checked oil levels (normal), as well as sat there and held the engine steady for about ~30 seconds per 100rpm from 2000-3000rpm and can't hear it (or maybe it's just not loud. I live alone so I can't have someone else help me out revving it). Just remembered I can rev the engine from under the hood and will try that out tomorrow too.
Any guesses here? It also sounds more prominent in the driver's seat than in the passenger's seat. (I leaned over heavily while driving and couldn't hear it as pronounced).
