FYI: Common Bolt Torque Reference Guide
102K views 12 replies 9 participants last post by  Linjr
#1 · (Edited)
Engine Bay:
  1. Battery Terminal Clamp: 3.0 ~ 4.4 lb-ft
  2. Engine Oil Filter: 11 lb-ft
  3. Engine Oil Pan Drain Plug: 25.3 ~32.5 lb-ft
  4. Ignition Coil (bolt to valve cover): 7.2 ~ 8.7 lb-ft
  5. Spark Plugs: 18 Lb-ft
________________________
Brakes:
  1. FRONT Brake Caliper Guide Bolts: 15.9 ~ 23.1 lb-ft)
  2. FRONT Brake Caliper To Knuckle: 57.9 ~ 72.3 lb-ft)
  3. FRONT Brake Caliper Hose To Caliper: 18.1 ~ 21.7 lb-ft)
  4. Brake Fluid Drain Pattern:
  5. Image
  6. REAR Brake Caliper Guide Bolts: 15.9 ~ 23.1 lb-ft)
  7. REAR Brake Caliper To Knuckle: 47.0 ~ 54.2 lb-ft)
  8. REAR Brake Hose to Caliper: 18.1 ~ 21.7 lb-ft)
SUSPENSION:
  1. FRONT Sway Bar Link Bolts: 72.3 ~ 86.8lb-ft
DRIVE-TRAIN:
  1. Differential(rear) Drain Plug: 36.1 ~ 50.6lb-ft
  2. Transfer Case Fill Bolt: 28.9 ~ 43.4lb-ft
  3. Transfer Case Drain Bolt: 43.4 ~ 57.9lb-ft
  4. Wheel Lug Nuts: 65.0 ~ 79.5 lb-ft
  5. Image
More Useful Links:
http://www.hyundai-forums.com/260-d...260-dm-2013-santa-fe/246089-2013-hyundai-santa-fe-fsm-field-service-manual.html
http://www.hyundai-forums.com/260-d...ms.com/260-dm-2013-santa-fe/162801-fluid-capacities-pocket-reference-guide.html
#3 ·
no problem at all. very often i'm in the garage and need a quick reference, without digging through FSM's and other websites.
ps: i print out pages from the FSM and put it into a binder, for the cars & bikes i own. but this is for those who dont do that. i like having quick reference sheets for common problems(brakes, fluids, belts, etc)
#5 ·
give me a few before you do it. i am still adding new items to the list (in between work lol)
#6 ·
Wheel Nuts Torque
After driving 100 km. on my new Michelin's, I brought my 2016 SFS Limited to my Hyundai dealership to get the wheel nuts re-torqued. After they finished re-torquing I asked what the torque wrench was set at. The tech said 100 lb-ft. The owner's manual recommends 65 - 79 lb-ft. This is the first vehicle I've owned with a torque range... it's usually just one number???
So... is there any harm torquing to 100 lb-ft? The tech said no.
#7 ·
The specs are for a reason. Now they have over torqued the studs.
But yes, I also found it odd when I rotated my tires recently and saw the range vs a set number.
#8 ·
My Nissan specs were 105, Ford 95, and Hyundai has a range so I do the top of the range at 80. Realistically anything in the 70-100 range is probably fine but the tech should have followed spec. He also likely does not zero out his torque wrench when not in use either.
#9 ·
1. 100lbs is a number that most shops use as a 'catch-all' number. rarely will any shop use a torque wrench to get the most accurate number. i personally use 100lbs and its never failed me yet. if you have concerns, go back and have it redone to the specs hyundai requires. i personally, wouldnt worry about it; as i use 100lbs. you would really have to go waaaaay over the specs to damage, or risk having a stud snap on you.
2. we have thread dedicated to popular bolt torque specs. merging with that.
http://www.hyundai-forums.com/dm-20...om/dm-2013-santa-fe/246097-popular-bolt-torque-reference-guide.html#post2113625
#11 ·
