Engine Bay:
Brakes:
SUSPENSION:
DRIVE-TRAIN:
More Useful Links:
http://www.hyundai-forums.com/260-d...260-dm-2013-santa-fe/246089-2013-hyundai-santa-fe-fsm-field-service-manual.html
http://www.hyundai-forums.com/260-d...ms.com/260-dm-2013-santa-fe/162801-fluid-capacities-pocket-reference-guide.html
- Battery Terminal Clamp: 3.0 ~ 4.4 lb-ft
- Engine Oil Filter: 11 lb-ft
- Engine Oil Pan Drain Plug: 25.3 ~32.5 lb-ft
- Ignition Coil (bolt to valve cover): 7.2 ~ 8.7 lb-ft
- Spark Plugs: 18 Lb-ft
Brakes:
- FRONT Brake Caliper Guide Bolts: 15.9 ~ 23.1 lb-ft)
- FRONT Brake Caliper To Knuckle: 57.9 ~ 72.3 lb-ft)
- FRONT Brake Caliper Hose To Caliper: 18.1 ~ 21.7 lb-ft)
- Brake Fluid Drain Pattern:
- REAR Brake Caliper Guide Bolts: 15.9 ~ 23.1 lb-ft)
- REAR Brake Caliper To Knuckle: 47.0 ~ 54.2 lb-ft)
- REAR Brake Hose to Caliper: 18.1 ~ 21.7 lb-ft)
SUSPENSION:
- FRONT Sway Bar Link Bolts: 72.3 ~ 86.8lb-ft
DRIVE-TRAIN:
- Differential(rear) Drain Plug: 36.1 ~ 50.6lb-ft
- Transfer Case Fill Bolt: 28.9 ~ 43.4lb-ft
- Transfer Case Drain Bolt: 43.4 ~ 57.9lb-ft
- Wheel Lug Nuts: 65.0 ~ 79.5 lb-ft
More Useful Links:
