Is the "Engine Software Update" defective and causing problems?. - Hyundai Forums : Hyundai Forum
 17Likes
post #1 of 61 (permalink) Old 03-22-2019, 08:26 AM Thread Starter
Quoted: 12 Post(s)
trentko1234 is an unknown quantity at this point
Exclamation Is the "Engine Software Update" defective and causing problems?.
I have a 2014 GLS with 68K on it. I had the engine software update performed 2 weeks ago. Today, after coming off a highway, my engine started bogging when accelerating onto a local road. Engine light now flashing. Parked car at work and noted that it wont rev over 1800rpm. I called service and they indicate this is the software kicking in. I am taking it in for service, but wonder:
Is this update causing unnecessary problems due to false-alarms? Does the update protect Hyundai from significant financial loss while placing undue hardship on the owners (Defective or otherwise problematic detection software that results in multiple false-alarms)?
trentko1234 is offline
post #2 of 61 (permalink) Old 03-22-2019, 09:08 AM
2011 Sonata 2.4GDI
Quoted: 804 Post(s)
deadrx7conv is an unknown quantity at this point
No, it is not causing unnecessary problems.
It will detect a failing engine. It can also trigger if the knock sensor is failing or if its wiring harness is defective. So, if the update was applied correctly, then you need 1 or more of what I mentioned.
Motto for advice giving on a forum: You can lead a horse to water, but you can't make it drink.
Sad country is where most neutered men can't change a tire or use a tire PSI gauge, can't check their engine oil or even pop their hood.
TrollBots are everywhere. Paid trolls are easy to spot in the 'off topic' forums everywhere.
Those who say it cannot be done, should not interrupt the person doing it.
deadrx7conv is offline
post #3 of 61 (permalink) Old 03-22-2019, 11:30 AM
forgeinaz's Avatar
Drives 14 Sonata SE 2.0T
Quoted: 257 Post(s)
forgeinaz is an unknown quantity at this point
The update is supposed to help prevent engine failure while driving and leave you with enough to limp to a safe place and maybe even back to dealer.
54strife likes this.
See, Flash, being the fastest isnt always the best if you are wrong.
forgeinaz is online now
post #4 of 61 (permalink) Old 03-25-2019, 11:25 AM
2014 Sonata SE Limited 2.4L [Pearl White]
Quoted: 13 Post(s)
Sonata330_Laura is an unknown quantity at this point
I had the 953 Update done in January (2014 Sonata SE - 42K miles). I did not have issues for another month, when my car went into limp mode. Received a new wiring harness. It happened again a few weeks later (limp mode). Now, my car has been at the dealer for TWO weeks undergoing tests and waiting to hear back from Hyundai corporate on what to do next. They have finally gotten back to my dealer - I will be having a new knock sensor installed today/tomorrow. Sorry to say, I have zero faith it will hold. I will be crossing my fingers and praying the next 5K miles or so, and then maybe I'll start to feel more confident. At the same time, I guess I won't be TOO upset if I need a new engine. But there are days I have to drive 200 miles for work, and I have family out of state I had planned on visiting soon. So needless to say, I'm nervous.
Sonata330_Laura is offline
post #5 of 61 (permalink) Old 03-25-2019, 11:52 AM Thread Starter
Quoted: 12 Post(s)
Thanks for replying. This is my fear/suspicion: Many people will be repeatedly inconvenienced by what amounts to being further burdened with defective software producing false alarms. This only adds to the aggravation and suffering of affected owners. If this turns out to be the case, I think the Judge should throw out the settlement and order Hyundai to immediately start replacing all "class" engines.
post #6 of 61 (permalink) Old 03-25-2019, 01:02 PM
grcauto's Avatar
Quoted: 1041 Post(s)
Let us know how that works.
grcauto is offline
post #7 of 61 (permalink) Old 03-25-2019, 02:14 PM Thread Starter
Quoted: 12 Post(s)
I know its a bit of wishful thinking. Probably more productive to initiate another separate class action (then a judge might join the 2).
post #8 of 61 (permalink) Old 03-25-2019, 02:47 PM
Bearcats's Avatar
Quoted: 407 Post(s)
Please let us know what the diagnosis was to your issue. Given that a car has millions lines of code through out and how well Hyundai tests stuff, anything is possible. I would be curious of the official diagnosis that if the code install was coincidental or not.
KDM YF LED tails | Llumar 30% Ceramic Tint | Precision LED 5K Interior lighting | XenonSupply 4300K Slimline HID's | The "cup" mod
Bearcats is offline
post #9 of 61 (permalink) Old 03-25-2019, 08:48 PM
hg3300's Avatar
Drives 2014 Sonata GLS
Quoted: 33 Post(s)
hg3300 is an unknown quantity at this point
I have a trip to Pittsburgh in July. They better get it straight before then.
hg3300 is offline
post #10 of 61 (permalink) Old 03-25-2019, 09:27 PM Thread Starter
Quoted: 12 Post(s)
Will do. So far - dropped car off 3/22/19. Was told by service Manager - 2 Scenarios: 1) Harness replacement - expect 7-10 days. 2) Engine replacement - expect around 6 weeks. I went back on 3/23 to retrieve some items and discussed further .... Here is where the wording gets interesting: "Hopefully, We'll hear back by Tuesday (3/26) how the company wants to proceed with your car". This "decision" process makes my imagination run wild....... I envision a large lottery-like machine with 100 balls inside. 99 balls have "Replace Harness" written on them and 1 ball has "Replace Engine" written on it........ I guess I'll just run with that theory until Hyundai details what this decision making process involves.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
