Gas pump keeps shutting off help! - Hyundai Forums : Hyundai Forum
post #1 of 12 (permalink) Old 12-05-2017, 02:44 PM Thread Starter
black sonata's Avatar
2012 Sonata SE
Quoted: 63 Post(s)
black sonata is an unknown quantity at this point
2012 Hyundai Sonata gas pump keeps shutting off like every 2 to 3 seconds. I have to halfway hold the pump leaver to get fuel in it. I noticed the car is also bad on gas now. I have no check engine light on. Help please.
black sonata is offline
post #2 of 12 (permalink) Old 12-05-2017, 03:48 PM
C4RN1's Avatar
Drives 2012 Sonata Turbo 1998 Eclipse GS (420a Turbo w/ 450 whp) SOLD!
Quoted: 321 Post(s)
C4RN1 is an unknown quantity at this point
That's something inside the fuel filler neck. Either the canister in there or one of the valves. If you want to do it yourself service it while the tank is near empty. Should be easy to remove it from the car, just take your time.
See that part labeled "12" vent tube? That's where I would start if I were you.
If this is over your head then you need to take it somewhere, either the dealer or a local mechanic.
C4RN1 is offline
post #3 of 12 (permalink) Old 12-16-2017, 06:36 PM
Drives 2013 Sonata GLS
Quoted: 23 Post(s)
That_Michael_Guy is an unknown quantity at this point
I had the same things with my 2013 Sonata GLS - the gas would shut off every few seconds. Frustrating.
Solution was to not insert the hose fully. Instead, insert it about 3/4 of the way in. Still more than enough that there's no chance of the handle falling out if left unattended, and it'll fill up the tank without shutting off once.
That_Michael_Guy is offline
post #4 of 12 (permalink) Old 12-16-2017, 06:48 PM
Location: Hiding from those who might be looking for me
Quoted: 2529 Post(s)
Suspect vent path is restricted,, likely canister problem.... removing 12 from atmosphere side of CCV still leaves tank to vent through canister... not an ideal test
I would remove large line from canister body and try refuel as a test.. if it fill up fine and dandy,, run with canister being fouled
sbr711 is offline
post #5 of 12 (permalink) Old 12-16-2017, 07:48 PM
2007 Honda CR-V auto
Quoted: 831 Post(s)
Suspect vent valve or Evap canister is clogged
avisitor is offline
post #6 of 12 (permalink) Old 12-18-2017, 11:46 PM Thread Starter
2012 Sonata SE
Quoted: 63 Post(s)
Im not getting a check light.
post #7 of 12 (permalink) Old 12-18-2017, 11:47 PM Thread Starter
2012 Sonata SE
Quoted: 63 Post(s)
Im not getting a check light?
post #8 of 12 (permalink) Old 12-19-2017, 12:13 AM
2013 Santa Fe Sport 2.0T Serrano Red Premium and Technology Packages 2001 Sonata 2.5 GLS
Quoted: 186 Post(s)
grandpaswagon is an unknown quantity at this point
Turn the nozzle all the way to the right - 90 degrees - when filling. Learned this from a Costco service attendant who has seen it all. Works every time.
This ties in with the info in post #3. Some nozzles are too long.
grandpaswagon is offline
post #9 of 12 (permalink) Old 12-19-2017, 10:53 PM
Quoted: 831 Post(s)
Hardly ever get a check engine light for this problem
avisitor is offline
post #10 of 12 (permalink) Old 12-20-2017, 04:36 PM Thread Starter
2012 Sonata SE
Quoted: 63 Post(s)
So this is something the dealer will have to scan without a check light?
