Can't Replace The Pcv Valve (not My Fault) - Hyundai Forums : Hyundai Forum
post #1 of 9 (permalink) Old 06-25-2007, 10:19 PM Thread Starter
gadgetadam
OK. I work on my cars as much as I can and I'm not a complete idiot. I've replaced clutches, brakes, timing belts, water pumps, radiators, etc, etc. My 2003 Elantra has 65,000 miles on it and a few years ago I tried to replace the PCV valve with no luck. The PCV valve is threaded into a copper/metal ring that is pressure fitted into the valve cover. When I tried to remove the PCV valve the copper/metal ring spun thus not allowing me to unscrew the PCV valve out of the copper/metal ring. Now when I try to unscrew the PCV valve the copper/metal ring spins in the plastic. I can't get the PCV valve out to replace it.
Does anyone have any tips or tricks to fix this?
Thanks.
-GadgetAdam
gadgetadam is offline
post #2 of 9 (permalink) Old 06-13-2009, 10:48 PM
ofhockey8
I have this same problem and i hope someone can help
ofhockey8 is offline
post #3 of 9 (permalink) Old 06-14-2009, 11:29 AM
theiceage05's Avatar
07 V6 3.3 Sonata GLS; 15 L4 1.6L Accent SE; and the Vantage 2005 Accent GS!
Quoted: 6 Post(s)
theiceage05 is an unknown quantity at this point
Hey there "burken" and "gadgetadam";
Could you guys post some digital pictures of your PCV valve/hose assembly.
A quick look at the HMAWebTech seems to be easy to remove.
"burken"; to the Forum.
"gadgetadam", your OP is dated 2007, did you get any help in removing it?
TheIceAge05
theiceage05 is offline
post #4 of 9 (permalink) Old 07-03-2009, 07:21 PM
beckylv79
I have a 2003 elantra and just last week my mechanic pulled the copper piece out, put the new pcv valve in it and JB Welded back into the casing on the valve cover. Didn't have $210 to get a new valve cover from Dealer!!
beckylv79 is offline
post #5 of 9 (permalink) Old 07-18-2011, 01:03 PM
y2kh8r
I've just run into the same issue, only I have to take the blame, I tried to wrench the valve off and I broke the metal piece free. Now it just spins. seems like poor engineering to me. Maybe the metal bit should have had splines? Or maybe it should have flat sides so it can be gripped? I tried holding the metal collar in place with a flat head screwdriver, but it just strips away the metal.
y2kh8r is offline
post #6 of 9 (permalink) Old 09-23-2015, 06:18 PM
Drives 2003 Elantra GLS
Mazinger is an unknown quantity at this point
Sorry to bring up an old thread, but this seems like a common issue. Anyone have any tips on the PVC valve replacement when the fitting it screws into also spins? I tried to replace mine and this also happened. I really want to avoid removing the valve cover.
Mazinger is offline
post #7 of 9 (permalink) Old 09-23-2015, 06:32 PM
Red Raspberry's Avatar
Quoted: 1645 Post(s)
Sounds like it needs pulled out and the jb weld back in is the fix.
You can't stand backwards on stairs......
Red Raspberry is offline
post #8 of 9 (permalink) Old 09-28-2015, 10:23 PM
Rkattek's Avatar
2010 Santa Fe AWD Limited Drives 2005 Elantra Sedan 5-speed
Rkattek is an unknown quantity at this point
2005 Elantra.
I too tried to take the PVC valve out and ended up sheering it off. Very poor design imho unless Hyundai never intended it to be replaced.
I took the valve cover off (not a difficult task) and then drilled out the old PVC valve (it is relatively soft so was quite easy to do without damaging the threads.
Chose a drill that was just a bit smaller than the hole that the PVC screws into so that the threads don't get damaged. At some point the metal from the PVC valve stem is so thin that it is easy to separate from the threads and pull out.
It was then easy to put in the new PVC valve.
If you don't take the valve cover off it is next to impossible to get at it.
Rkattek is offline
post #9 of 9 (permalink) Old 10-03-2015, 06:12 PM
Thanks, Rkattek.
Guess I'll pull off the valve cover and see what I can do. At least it's easy on this car.
Mazinger is offline
