2004 elantra gls - Hyundai Forums : Hyundai Forum
post #1 of 14 (permalink) Old 05-26-2019, 09:04 PM Thread Starter
Elantra04gls is an unknown quantity at this point
2004 elantra gls
Hello, recently I have been having an issue with my elantra. Usually it happens after the engine is warm when I am cruising and I come to a stop or put it in park it will misfire like crazy. At this time if I push and give it more throttle it clears up and goes away. It only does it a very low speeds or idling, regular driving speeds it works just great. Has anyone had this type of issue before that could point me in the correct direction?
Elantra04gls is offline
post #2 of 14 (permalink) Old 05-26-2019, 10:08 PM
flemmons's Avatar
2015 Sonata Sport, 2014 Elantra GT, 2016 Elantra SE.
Quoted: 406 Post(s)
flemmons is an unknown quantity at this point
Need some more detail;
How long have the plugs been in the engine, and are they the factory spec spark plugs?
Have the fuel injectors been cleaned?
How many miles?
flemmons is offline
post #3 of 14 (permalink) Old 05-26-2019, 10:27 PM
Location: Hiding from those who might be looking for me
Quoted: 2549 Post(s)
MIL ??
Scan it yet ??
XD Elantra,,, wires is suspect, look at sticks that extend into plug tube... Plugs is NGK Platinum,, 60,000 interval..
I really suspect you'll find a misfire 3 or 4 code,, to which I want you to spray some water with spritz bottle,, or easier yet, a can of carb or brake clean spray,,,,, spritz along seam where intake manifold bolt to cylinder head with engine warm at idle...
IF gasket is cracked / broken,,,, you know it when spray hits vacuum leak and get into engine...
sbr711 is online now
post #4 of 14 (permalink) Old 05-27-2019, 12:59 AM
2007 Honda CR-V auto
Quoted: 839 Post(s)
Yeah, was thinking it could be a vacuum leak on the in-take manifold.
Had very small break in the manifold gasket which caused a misfire
Wasn't as bad as you describe yours
Would try what SBR711 said to do
avisitor is offline
post #5 of 14 (permalink) Old 05-27-2019, 03:08 PM Thread Starter
Wow thanks for all the responses. I was actaully able to get it to auto store today to get the codes read. Attached are pictures of each code. Info on the car it has 165k miles I bought it with 145k miles and I have no idea if the spark plugs have ever been replaced I check all the coils and I don't see any messed up wires or anything.
post #6 of 14 (permalink) Old 05-27-2019, 08:53 PM
Remedy the MISFIRE 1 first.... clear codes and see what happen..
That pre-cat OX Sensor is a very expensive part... 6 wire wideband sensor
post #7 of 14 (permalink) Old 05-28-2019, 05:53 PM Thread Starter
What do you recommend to fix the mis fire spark plugs? Coil?
post #8 of 14 (permalink) Old 05-28-2019, 11:02 PM
Quoted: 839 Post(s)
Do the tests to find the cause of mis-fire.
Then fix
avisitor is offline
post #9 of 14 (permalink) Old 05-29-2019, 03:52 PM Thread Starter
Is there a way to test the coil?
post #10 of 14 (permalink) Old 05-29-2019, 11:47 PM
Quoted: 839 Post(s)
Do you know which cylinder is mis-firing?
If not then do a power balance test
That is when you take off one spark plug wire at a time to see if it has any affect on engine
If no effect then that cylinder is not contributing to the power output.
If it does affect the engine then cylinder should be good
The bad cylinder could be coil, spark plug or wires
avisitor is offline
