Veracruz Transmission fluid maintaince. - Hyundai Forums : Hyundai Forum
 2Likes
post #1 of 34 (permalink) Old 04-01-2014, 02:21 PM Thread Starter
Hyundai Veracruz
Minghai.pei is an unknown quantity at this point
I am really confused that the VC transmission fluid is lifetime and no need to be changed as it is said in the Manual's.
Can anyone explain it to me?
And if you have to do change the transmission oil, pls suggest me how and what kind of the transmission oil that is the best for VC.
Tks a lot for your kind reply and helps.
BTW, my VC's ODO has reached 150.000kms. Is that too much?
Minghai.pei is offline
post #2 of 34 (permalink) Old 04-02-2014, 04:23 PM
none
hamdeu is an unknown quantity at this point
As I asked before at the agent here (Bahrain) I got the same answer as yours ( VC transmission fluid is lifetime and you shouldn't change it at all) . my fathers 2008 VC ODO is 180000 and no problems with the transmission . I suggest that you don't change it since it is fully sealed "no dipstick" and since you don't have any problems in the transmission " even if you do it might not be from the transmission for example there are an air sensor that my father had to change which caused the gear to stuck at 3rd at all time" .
for altima 2008-2012 CVT transmission costs around 5000 USD "comes with dipstick" and you have to change the transmission fluid every 200000 KM or you will have to change the transmission .
hamdeu is offline
post #3 of 34 (permalink) Old 04-03-2014, 11:28 AM Thread Starter
Hyundai Veracruz
Thanks a lot for your kind advise, bro. I may not change the oil as told by my local Hyundai Technician.
He just suggested me to check the transmission oil and if it is short of volume, he can refill it or change the whole volume....
I am really confused.
post #4 of 34 (permalink) Old 04-03-2014, 01:04 PM
Location: Hiding from those who might be looking for me
Quoted: 2459 Post(s)
You are free to change ATF in trans anytime you desire.
Clean ATF never varnished up fibers and plates/seals like old used ATF..
sbr711 is offline
post #5 of 34 (permalink) Old 04-04-2014, 10:34 PM
Don67's Avatar
Drives 2012 Volvo S80, 2018 Silverado. Daughter owns the 2011 Elantra now.
Quoted: 255 Post(s)
There is no such thing as a "sealed" transmission... only claims of being maintenance-free for the purpose of selling more cars.
The Veracruz's transmission is a solid Aisin unit that sees duty in Volvos and other cars, but in a 4500-pound CUV it will almost certainly be the first major component to die if you don't take care of it. Many minivan and CUV owners have learned this the hard way. Change the fluid.
Don67 is offline
post #6 of 34 (permalink) Old 12-29-2014, 01:42 PM
Drives 96 Maxima, 2013 VW TDI Passat
Quoted: 2 Post(s)
gsleve is an unknown quantity at this point
I am aware that this thread is old, nonetheless this information may shed some light on performing maintenance on a fill for life transmission, and how to perform this procedure. I could not find a procedure outlining the steps to take however I have performed this procedure on all the automatic transmissions I have owned in the past (yet the all had a filler tube) and it has worked wonders.
This weekend, I just changed out over 10qts of transmission fluid from a 2007 Veracruz total capacity is 10.9 liters which equates to 11.5 qts (I believe)
1. Tools needed for fill plub torx-t55, drain check plug torx-t45, IR gun, funnel.
2. Fluid Valvoline Max Life synthetic fluid that meets the jw3309 spec from hyundai
3. Two bottles lubeguard red.
First one needs to remove the black air duct two black plastic screws connected to the top of the railing of the car. Once removed try to use the t55 torx to crack open the fill plug it is really tight.
Go underneath and remove the plastic cowel there are about 8 bolts.
Go back to the engine compartment. Looking down you will see two rubber coolant lines with clips holding them to the transmission cooler. Remove the the bottom coolant line and direct it straight down to where you removed the bottom engine cowel.
Direct the hose into a gallon jug that is marked to measure 4qts. Have an assistant start the vehicle with the emergency brake on and vehicle in park. Allow the jug to fill up to the half way mark, tell assistant to shut vehicle off. Pour in 4qts of Valvoline max life full synthetic tranny fluid using a funnel. Reason for over fill is NOT to allow the tranny to run dry.
Start vehicle again and and allow fluid to fill to the 4qt marking made on the gallon jug, shut car off. Get another jug marked the same way. Start vehicle and run until the fluid reaches measured 4qt marking. Stop vehicle and pour in another gallon of Valvoline maxlife full synthetic fluid.
At this point you should have drained 2 gallons of fluid and refilled transmission with two gallons of fluid.
Grab another jug with the 4qt marking, make another marking at the half way point. Start vehicle and fill to the half way mark and stop engine. Refill transmission to with another (half gallon only).
Raise vehicle in the air and on jack stands have assistant put car in drive and raise the vehicle to 55-60 mphs and run this for about five minutes, have them let of the gas and allow the mph to fall to zero and place the vehicle in park.
Use the IR gun and point it to the bottom of the transmission to take a reading then point the IR gun to the transmission pan and take a reading between the two readings you will need to get between this temperature range 120-140 degrees. If the reading is not there yet, repeat process of jacking car in the air and race engine to 50-60 mph to lock torque converter and heat the tranny fluid.
Drop the vehicle and have the assistant press on the brake and place the vehicle in R, N, D, and other gears pausing in between for 2 seconds, now have them reach to the Park again pausing for two seconds in between gears.
Us the IR gun take the temp readings, once these readings are between 120-140 degrees (preferably the lower allows time to check fluid level).
It is a must the vehicle needs to be running in park. Place a pan underneath and use the torx t45 to loosen bolt and remove this bolt, transmission fluid should flow at a steady stream or a drip (preferably at a slow drip), if no transmission fluid is coming out, put plug back in tighten and shut vehicle down. Add half a quart of transmission fluid and add the two bottles of lubegard red.
If you are at a slow drip then add two bottles of the lubeguard transmission protectant.
Your done. Hope this helps (oh by the way the original fluid from the veracruz was black for the first two gallons and became red on the the third gallon).
doug.crabb1 and dgrein like this.
gsleve is offline
post #7 of 34 (permalink) Old 12-30-2014, 10:07 PM
Don67's Avatar
Quoted: 255 Post(s)
Outstanding post, gsleve. Thanks for sharing.
Will use this for my Veracruz and maybe my Volvo too :-)
Don
Don67 is offline
post #8 of 34 (permalink) Old 01-01-2015, 02:01 PM
Veracruz 2007
vnemi is an unknown quantity at this point
Thank you very much. Was there a crush washer on the fill port? If yes, do you know the size / replacement part number? Any other consumable (clamps, clips etc.) that you recommend replacing at the same time?
Many thanks.
vnemi is offline
post #9 of 34 (permalink) Old 01-01-2015, 02:28 PM
Veracruz 2007
If it helps, here is the ATF leveling guide from the manual
the replacement o-rings are listed, they seem a very strange size to be given in mm, do they match up with some "standard" dimensions? anyone know the part numbers?
vnemi is offline
post #10 of 34 (permalink) Old 01-18-2015, 12:36 PM
2010 Hyundai Veracruz Limited
cmyers2220 is an unknown quantity at this point
I thought it didn't need replaced either till my dealer had me look at the extreme condition schedule(since I live in Ohio which has major temp swings). The manual there says to change the trany fluid every 60k, which I am having them do this week. I found it hard to believe under "normal" conditions you would never have to replace it.
cmyers2220 is offline
