Vibration/Power problem at certain revs. - Hyundai Forums : Hyundai Forum
post #1 of 7 (permalink) Old 03-18-2019, 11:03 AM Thread Starter
Drives Hyundai Trajet 2.0 CDI Manual 2006 (RHD - UK)
Quoted: 2 Post(s)
piggzy is an unknown quantity at this point
Unhappy Vibration/Power problem at certain revs.
Hi all,
Got a 2006 Trajet 2.0 CDI Manual.
Before I purchased it the car was sat around for 6+ months not started or driven at all and wonder if this could be related to my issues.
Basically the car has a vibration at roughly 1500-1700 revs in every gear. If you use barely any throttle going through this range you barely notice but the more throttle the louder stronger the vibration and it seems to struggle as if going up a hill. As soon as above 1700ish revs no problem at all.
I have zero vibration in either clutch pedal or gear stick and all gear changes are smooth.
The vibration seems to come from the top end of the engine area right behind the dash.
Also which I am guessing is related it seems pretty poor on fuel.... drinks it like a fish unless I am expecting too much from it lol
No engine lights at all. The only other issue is the ABS currently disabled by removing abs fuse as I need to fit a new abs ring as it is cracked.
A bit of a head scratcher. Have checked air filter which looks fine.
Appreciate any tips on what to check.
piggzy is offline
post #2 of 7 (permalink) Old 03-18-2019, 11:23 AM
grcauto's Avatar
Quoted: 1005 Post(s)
Originally Posted by piggzy View Post
Hi all, Got a 2006 Trajet 2.0 CDI Manual.
Do you have the vibration while parked and force engine to 1700+ rpm?
Best practices for requesting help:If you haven't done so fill in your vehicle info and profile page. At upper right corner under the search box click on user cp (it's your control panel)
This info will show up to the left under your user name and is very helpful.
BE SURE TO ADD YOUR LOCATION SO WE KNOW WHAT MARKET YOU ARE IN.
  • Be sure you are in the correct forum for your vehicle.
  • Do a search for your problem. A lot of stuff has been asked and answered.
  • Do not double post for the same problem.
  • Give the model year....Engine size...transmission type (auto or standard)
  • Take a single issue at a time. Posting multiple issues at once will get convoluted very quickly
  • VIN number can be very helpful
  • Vehicle history can be good. How many miles. If not bought new, how many have you put on it.
  • Describe the problem best you can. If a noise can you get a sound or video file
  • Tell us what has been done, if anything, thus far. If tests have been performed give actual results not OK or passed. If scanned for codes the actual code(s) not O2 sensor or MAF, Etc.
  • If the vehicle has been to a repair facility it would be nice if you could post a picture of that invoice/bill
  • If your vehicle is under warranty you should have the dealer check it out. If it's a problem they see many times they will generate a safety recall of TSB. This is how they know of the problem.
This information can save a lot of time and get you the answers you need much faster.
Thanks,
Welcome aboard.
grcauto is offline
post #3 of 7 (permalink) Old 03-18-2019, 03:59 PM Thread Starter
Quoted: 2 Post(s)
Thanks for reply.
No I have no issues of vibration while stationary in neutral.
It only occurs under load and in gear. I don't notice it in first gear but as the range from 1500-177rpm is VERY short in first I wouldnt expect to.
As you expect in every susequent gear change as 1500-1700 revs last longer then so does the vibration and is more pronounced.
Cheers.
piggzy is offline
post #4 of 7 (permalink) Old 03-18-2019, 04:32 PM
grcauto's Avatar
I would think you would fell it in the shifter if it were the transmission. Sounds like it's not a death rattle so drive it until it gets worse or you get used to it.
grcauto is offline
post #5 of 7 (permalink) Old 03-19-2019, 07:13 AM
Hyundai Trajet 2.7, Kia Optima 2.5, some BMWs
Quoted: 93 Post(s)
e3tom is an unknown quantity at this point
Vibrations are very hard to diagnose but by logic:
small rpm band showing the issue
in every gear
chances are that the dual mass flywheel ist toast
Maybe the reason for this vehicle to be sold, since you're looking into a 2000€ bill then ...
e3tom is offline
post #6 of 7 (permalink) Old 03-29-2019, 11:31 AM
Quoted: 93 Post(s)
So, well, any news about this case ?
e3tom is offline
post #7 of 7 (permalink) Old 04-06-2019, 03:03 PM
Quoted: 93 Post(s)
dumped it, maybe ... last activity March 23
e3tom is offline
