I have replaced the stereo with a Bluetooth one and every time I turn it on, the antenna activates and after I switch it off the antenna wouldn't be able to retract all the way(since it's old) which is annoying since I use Bluetooth. I just want to know where the antenna location is so I could be able to disable it and maybe one day I would replace it with a manual antenna. I tried to access it from the glove box (right-hand drive model) but I wasn't able to locate it. Any help would be much appreciated. :)
If you don't want the antenna to extend just disconnect the power antenna wire at the radio. It's usually a blue wire on aftermarket radios.
