My Wiper Washer Pump stopped working on my '05 Accent. I can't hear it running so I assume that the pump has stopped working. I checked the fuses and the wipers are on the same circuit as the washer pump. The wipers still work.
Where is the pump located? It looks like it may be under the fender where the reservoir is. But I want to know for sure before I start tearing the car apart.
Any ideas?
Thanks!!!
there have been dozens of post about this subject in the past (try the search engine)
the pump in fitted in the bottom of the washer tank under the right hand front fender (you may need to remove the road wheel and the inner plastic wing shield)
