I just tried to fill up my water bottle for the windscreen washer and all the water flowed straight out the bottom.
With my phone light and a bit of feeling around noticed a nodule had broken off the pump.
Question: Can you just replace the pump or do you need to replace the whole unit?
Thanks in advance.
WMFP
You can buy the pumps either from your local Hyundai dealer or from some car parts retailers like Supercheap.
Make sure you get a pump that has two outlets one for the front windscreen and one for the rear washer.
I had to replace the pump on my son's Getz a year or so ago.
His is a 2006 model and the pump is at the base of the washer bottle under the right side headlight.
Easiest way is to take the right front wheel off, remove the inner guard plastic liner and you can work on it from there.
Regards Gerry
