Hey all,
Having a window regulator issue on my 2007 Sonata GLS.
About a month ago my front drivers side window wouldn't go up all the way, but right before it failed it was making this cracking/crunching sound when going up, then it just failed a couple of inches from the top.
So I ordered a new drivers side regulator and the passengers side as well, cause that side might be going soon is my guess.
Replaced both and the drivers and passenger sides with the new regulators and now the drivers side works and feels like new. However the passengers side seems worse, goes down a little slower than before and goes up way slower than before. I have noticed one side seems to go up before the other, in other words the passenger window is now not going up evenly, which maybe causing a cracking noise towards the top. As if it's showing signs like the regulator is failing.
But it is a new regulator. I am thinking I should remove it and inspect it closer and maybe even spray the tracks down with lithium grease or silicone grease. If that doesn't work reinstall the old one.
